2 members (FishinToms53, Hotrod Lincoln), 128 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
I am on the look out for a new or good used accelerator linkage pivot pin; the one that screws into the side of a 6 cylinder (235) engine block.
Does anyone know where I can get one of these?
Walt Williams
La Verkin, UT
I think you will find this is the correct style LINK
My Blog
Dave,
That Filling Station part appears to be for 50-62 5-cylinder engines.
Thank you and Joe for posting this information.
The "5 cylinder" is pretty funny. Must have a bad valve.
My Blog
In the old days, I heard of people who had one bad set of rings or one bad rod; and, they supposedly simply removed the rod and maybe the piston. They then ran on five.
Does balance and harmonic vibration ring a bell??????
Don't see how it would run very long before breaking a
crankshaft unless it was balanced with a bob weight
in place of the rod and piston.
Denny G
Denny G
Sandwich, IL
I have no idea how long they would run, Denny, but I would chuckle when I heard the antics/fixes used to keep an old farm truck running.
Another unorthodox "repair" was to file the mating surfaces on rod bearing ends for a tighter fit (they even used plastigauge - this was precision work) - to "fix" rod knocks and/or low oil pressure.
I filed many rod caps. No plastigage. Just fit them till you could tap it back and forth on the journal with a small ball pein hammer.
And got a lot of useful miles out of them.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
The 216 would have an advantage with the 5 piston mod because it wouldn't affect the oil pressure!
1951 1 Ton Completed
Or you could use someones bench lathe and make on:
http://www.pbase.com/dennygraham/image/148495584
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
