| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | I am on the look out for a new or good used accelerator linkage pivot pin; the one that screws into the side of a 6 cylinder (235) engine block.
Does anyone know where I can get one of these?
Thanks Walt Williams La Verkin, UT | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I think you will find this is the correct style LINK
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
That Filling Station part appears to be for 50-62 5-cylinder engines.
Thank you and Joe for posting this information.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The "5 cylinder" is pretty funny. Must have a bad valve.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In the old days, I heard of people who had one bad set of rings or one bad rod; and, they supposedly simply removed the rod and maybe the piston. They then ran on five.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Does balance and harmonic vibration ring a bell?????? Don't see how it would run very long before breaking a crankshaft unless it was balanced with a bob weight in place of the rod and piston.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have no idea how long they would run, Denny, but I would chuckle when I heard the antics/fixes used to keep an old farm truck running.
Another unorthodox "repair" was to file the mating surfaces on rod bearing ends for a tighter fit (they even used plastigauge - this was precision work) - to "fix" rod knocks and/or low oil pressure.
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I filed many rod caps. No plastigage. Just fit them till you could tap it back and forth on the journal with a small ball pein hammer. And got a lot of useful miles out of them. Cleon | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 216 would have an advantage with the 5 piston mod because it wouldn't affect the oil pressure! | | |
