Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TUTS 59, Hanks custodian, Bill Hanlon, Wally / Montana), 137 guests, and 6 robots.
Topics128,288
Posts1,058,569
Members48,492
Another custom detail: I installed some modified bed side trim across the back of the cab at the two tone paint break line.
Pretty subtle, but it visually ties the custom cab b-pillar trim panels together.
http://i645.photobucket.com/albums/...%20Pickup/Side%20Trim/TwoToneTrim005.jpg
http://i645.photobucket.com/albums/...%20Pickup/Side%20Trim/TwoToneTrim001.jpg
http://i645.photobucket.com/albums/...%20Pickup/Side%20Trim/TwoToneTrim002.jpg
Intersting upper brake light. Now how about a bead of stainless around the drip edge? Too Much?
Nice. It looks as if it should have been there all along.
Drew
Looks good, My 62 is the same color. I have seen a few with what seemed to be a factory correct molding. But it may have been used in only in 1960. None of the newer trucks have it. Does any one know for sure??
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Originally Posted by Howies551Ton
... I have seen a few with what seemed to be a factory correct molding. But it may have been used in only in 1960. None of the newer trucks have it. Does any one know for sure??
Here's another thread that discusses the rare back cab trim, the thread is entitled "1960 Custom Cab Back Cab Trim", $260 seems ludicrous though for a piece of $50 trim. If I was a dishonest guy I could make a buck with this... dance http://67-72chevytrucks.com/vboard/showthread.php?t=560847&highlight=trim
Nice touch. Good job.
The factory trim, terminates with the run-out on the cab sail, with a flanged lap joint, similar to the spear & front fender trim. The run-out is back-flanged and the horizontal trim, under the window, nests on top of the back-flange.
So is the 1960 B-Pillar trim different due to the flanged lap joint?
That looks nice. It does look like it should be there.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
hotrodjohn, did you used to be lakeroadster? The truck looks familiar.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks for the positive compliments fellas thumbs_up
Yep! Lakeroadster = Hot Rod John
Lakeroadster: I picked this name when I started building my '27 Ford Roadster Pickup, circa July 2000. I built it as a "Lakes Roadster": http://i645.photobucket.com/albums/...Ford%20RPU/2009_10180026_zps3166a719.jpg
Hot Rod John: this is the nickname my buddies here in Colorado call me. Used this member name when i started looking for a vintage Chevy pick-up in July 2008 and joined the crew here at The Stovebolt: http://i645.photobucket.com/albums/...0Pickup/2621897210103882008mTylTc_fs.jpg
I thought the truck looked familiar, I was following the build on that other board and poof one day it was gone. Funny place over there, they like to toss good folks.
Looks great
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
If your interested I keep this updated: http://talk.classicparts.com/showthread.php?t=13928
