4 members (Jim K, tclederman, Lightholder's Dad, Biermann), 113 guests, and 0 robots.
Topics128,163
Posts1,056,918
Members48,458
#913043 01/20/2013 7:26 AM
Any good tips on freeing a stuck E-brake (hub type)
thanks
What part are you trying to free?
1951 1 Ton Completed
looks like all of it. The shoes are expanded for no apparent reason other than the e-break being stuck
themhandle moves in the cab but has no effect on the drum portion of the system
Don't know how similar your e - brake is to my 56, but I had to replace both e-brake cables from the drum to the connecting lever. Mine were sheathed cables, not sure yours are sheathed or open cable. That fixed my problem. I was systematically able to clean and free all other cables and connections all the way back to the cab so that stuff is still original. Probably not much help, but you will need to find out where the action stops after you engage the brake pedal or handle, whichever it is.
Dale
