| | | Forums66 Topics128,050 Posts1,055,683 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | This may sound stupid but Can anyone tell me if a Chevy C60 is a 1 1/2 or a 2 ton ?? Thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Hi Hotshoe, I think a c 60 might be a 2 1/2 ton. If you think about it, a C30 is a 1 ton there was a C40 which should be a 1 1/2 ton, & I think there was even a C50, which would make that a 2 ton. Im not 100% positive , but i think this is right. Someone will chime in if im wrong.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have never heard a C60 called anything but a 2 ton. The whole tonnage rating is archaic and was already meaningless by the time C40, C50 and C60 trucks were built. I have heard C40 called a 1 1/2 ton light duty and a C50 called a heavy duty 1 1/2 ton, but again the tonnage rating has nothing to do with the actual load capacity. | | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | Thanks for the replies. I made a deal with a guy for his lockout hubs on a napco axle. I happen to need them for my 1 1/2 ton and my 2 ton.Part of the deal is he gets my parts so his truck is drivable. I'm trying to make sure I send him the right parts the first time. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I had gotten into the 60-66 LCF (Low Cab Forward)trucks some years ago, & accumulated about 5, or 6 of them. I had a '65 L60, which was a 2 ton, a '64 L60H (Heavy Duty 60 series), which in 1964 replaced the L70 series that existed thru 1963, which was rated as a 2 1/2 ton, & two L80 series trucks (a '60, & a '65 model)which were 3 ton trucks according to the info., I had on them. This being said, there were C60, C60H, & C80 trucks. I'm guessing they would have been the same. Hope I didn't confuse you.
| | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | So I'm leaning toward sending the 2 ton parts. Looks right from the outside. The Napco is for my 1957 LCF. Love those trucks. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Welcome,hotshoe99! Do you have pic's? Did you do the work yourself? I'm sure that I'm not the only one interested in your truck. Please keep us "posted". | | |
