7 members (mason86, 55shaker, Paul Mullen, Peggy M, walter74, Bill Hanlon, Hotrod Lincoln), 62 guests, and 0 robots.
Topics128,050
Posts1,055,680
#912937 01/19/2013 5:01 PM
This may sound stupid but Can anyone tell me if a Chevy C60 is a 1 1/2 or a 2 ton ?? Thanks
hotshoe99 #912939 01/19/2013 5:10 PM
2 ton
hotshoe99 #912941 01/19/2013 5:15 PM
Hi Hotshoe, I think a c 60 might be a 2 1/2 ton. If you think about it, a C30 is a 1 ton there was a C40 which should be a 1 1/2 ton, & I think there was even a C50, which would make that a 2 ton.
Im not 100% positive , but i think this is right.
Someone will chime in if im wrong.
hotshoe99 #912965 01/19/2013 7:08 PM
I have never heard a C60 called anything but a 2 ton. The whole tonnage rating is archaic and was already meaningless by the time C40, C50 and C60 trucks were built. I have heard C40 called a 1 1/2 ton light duty and a C50 called a heavy duty 1 1/2 ton, but again the tonnage rating has nothing to do with the actual load capacity.
hotshoe99 #912968 01/19/2013 7:30 PM
Thanks for the replies.
I made a deal with a guy for his lockout hubs on a napco axle. I happen to need them for my 1 1/2 ton and my 2 ton.Part of the deal is he gets my parts so his truck is drivable. I'm trying to make sure I send him the right parts the first time.
hotshoe99 #912969 01/19/2013 7:31 PM
I had gotten into the 60-66 LCF (Low Cab Forward)trucks some years ago, & accumulated about 5, or 6 of them. I had a '65 L60, which was a 2 ton, a '64 L60H (Heavy Duty 60 series), which in 1964 replaced the L70 series that existed thru 1963, which was rated as a 2 1/2 ton, & two L80 series trucks (a '60, & a '65 model)which were 3 ton trucks according to the info., I had on them. This being said, there were C60, C60H, & C80 trucks. I'm guessing they would have been the same. Hope I didn't confuse you.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
hotshoe99 #912971 01/19/2013 7:40 PM
So I'm leaning toward sending the 2 ton parts. Looks right from the outside. The Napco is for my 1957 LCF. Love those trucks.
hotshoe99 #914373 01/24/2013 7:31 PM
Welcome,hotshoe99! Do you have pic's? Did you do the work yourself? I'm sure that I'm not the only one interested in your truck. Please keep us "posted".
Mo' Tater
