4 members (Nick in Manitou, Stovebolt48, diseasel, Johnny Rib), 106 guests, and 2 robots.
Topics128,035
Posts1,055,559
#91266 05/23/2005 9:13 PM
Hi, I bought my dream truck a couple of months ago, 1953 5 window, aka rustbucket basket case. I have been doing research and planing my restoration of the beast.
The wiring in the engine compartment looks like a crack smoking slacker messed it up. I have not had it running as of yet, but I anticipate I will want to change this all out.
My questions are, has anybody used the EZ wiring harness, if so which specific harness set up and was it easy? Or has anyone done the Painless wire harnes with the same questions?
I don't plan for electrical windows or A/C in the next 3-5 years, however; plans change and I may have wished for the bigger wiring harness. Any thoughts?
If this has already been discussed on a thread please lead me in that direction.
Thank you all for the continued support.
Dan
Colorado
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough!
53 5window 1/2 ton
54 3window 1/2 ton
#91267 05/23/2005 11:24 PM
I have used the EZ kit sveral times and it has worked fine for me. The unit is a lot like an OEM, in the way the wires attach to the fuse block, no clips or screws. It's labeled nicely and has plenty of wire length. If you have been checking around you know the pice is right. The only bad thing is that the instructions are a little weak. They may be better now, (this was 2 years back) they seemed to know then that they were soft in that department. All in all I would use them again, if only for the price. Good luck Richie Z
#91268 05/24/2005 7:10 AM
Do yourself a big favor ... strip your truck bare of all old wires and start fresh. That's what I did and it was not rocket science.
I bought the EZ-Wire kit ... every bit as good as Painless for a lot less money; only $160 -- you can read all my install notes and tips, links to the EZ-Wire harness, etc. HERE
It seems like a big project, and it is ... took me 10 days ... but it was also a lot of fun! And if you just tackle the project with a "one-wire-at-a-time" approach, it's easy as pie.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#91269 05/24/2005 2:40 PM
Thanks for the imput Richie and Alan.
I look forward to the challange and the learning experience.
Alan, I think I read your 10 day ordeal. That means mine will be a 20 day ordeal... smile That is how things go for me.
Thanks again guys, it is good to hear from actual stovebolt guys who have used the EZ-wire harness.
Dan
Colorado
53 5window 1/2 ton
54 3window 1/2 ton
#91270 05/25/2005 8:00 AM
Junior Member
Junior Member
If you decide to go stock replacement, the Chevyduty harness is not that bad. It took me a weekend to put in. 100. bucks or so
#91271 05/26/2005 12:58 AM
Junior Member
Junior Member
hi big guy ! i was wondering if you can tell me which wires i would hook up from the old wiring harnes on my 58 gmc pickup to the 1980 305 engine to get power to the fuse panel for lights and heater to be able to work? MM
