3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
So I just can't get my Hydraulic Lifter issue under control. The rebuilt ( NOT! ) engine I bought had used lifters in it, they would start out nice and quiet and then start to tick when warmed up. So I bought a complete set of new lifters,installed and adjusted. They start out noisy and after 10min of driving they quiet down and will stay quiet. This is everytime I cold start the engine, when restarting after warmed up they stay quiet, but after sitting overnight, BAM, noisy. I'm using a straight 30wt, an old timer says that's my problem, " oils to thick, need a multiweight in there ". Is this true? Could this be my issue?? I would LOVE to remove these hydraulic lifters and pushrods and install a solid lifter/pushrod setup, but I know I can't, I'm stuck with what I bought :mad:
3B Offline
Hy AZ59apacheguy, the 30wt. oil would not be the problem, how is your oil pressure? Usually once a lifter is full of oil they don't usually leak back down, could there be an internal oil delivery blockage in the block? What engine are we talking about?
Hi, thanks for the reply. Sorry, it's a 235. Oil pressure upon start up is above 30lbs and will stay there untill the oil warms up and thins a little.
Lifters that are noisy on start up, then quiet down when they warm up, will usually quiet down after they wear in.
My Blog
I have similar circumstance occurring. 62, 283 in my case. How do I diagnose oil pressure, or oil delivery problems? I don't have a pressure gauge. Only a warning light in cab.
~ HB
1962 Chevrolet C10
1962 Suburban
How do you have them adjusted?
zero lash
1/2 turn down
3/4 turn down
1 turn down
Try to adjust one with the engine running, tighten it till the engine misses (holds valve open) then loosen till the rocker arm ticks. This will give you a idea of how much internal travel the lifter has. I would stay on the deep side of the travel range.
Joe
zero lash
1/2 turn down
3/4 turn down
1 turn down
Joe
This is what I ended up doing, so far they are a quiet. They were even quiet upon start up. We'll see they sound after a long drive. I'll let ya know this weekend.
Here's a thread to a tech tip by Tom Langdon re. these noisy lifter. Appears to be very common problem. Best of luck
http://stoveboltengineco.com/2002/04/noisy-lifters/
1946 1/2-Ton Chevy
Originally Posted by AZ59apacheguy
[quote=Joe H]
Well, they are still noisy. I guess I'll keep driving and see if they break in and get quiet like someone else stated earlier in this thread
