2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I've got a line on an engine and rear axle from a 1954 passenger car. I expect the axle has a better ratio than my 53, and that the 235 might do nicely in place of my 216 with a cracked block. How easy is it to exchange the axle?
Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | if im not mistaken the 54 car wont fit. torque tube lengths are diff, you could use the engine which would be a improvement over the 216. 55 and up 235s are better and easier to find parts for then the 53/54 235s. you can swap the third member from a 55-59 pickup , that would bolt right into your existing Axel and give you 3.9 instead of 4.11 ( manuals had 3.9, overdrives had 4.11 and autos had a 3.23 or something high like that.) but that requires a drive shaft, open drive transmission and welding on the swivels on the Axel . or the Patrick swap. or there is a 50/51 chevy passenger swap ( link in the tech tip section)i think but that requires some work as well. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ......not sure about this but I THINK the 3rd member will fit and AD up thru 1962?? ... and I THINK the automatic is a 3:38 maybe someone that knows for sure will chime in. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1954 car with manual transmission had a 3.70 rear end. The 1954 car with Powerglide automatic transmission had a 3.55 rear end.
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | Will th passenger rear work for him? I thought the passenger is smaller in diameter ( entire 3rd member) and a diff length. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | drew,
I think you are correct.
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Thanks for the ideas, guys. I have another 235 waiting for the pickup. But I also might need a substitute motor for my 41 sedan, so having two might have been a good idea. But the better idea is simply to start fixing these original motors. The 216s are enuf for me. I am happy driving 55. Ditto with the axle I guess
