3 members (Hotrod Lincoln, baldeagle, Lightholder's Dad), 42 guests, and 5 robots.
Topics128,018
Posts1,055,339
Members48,419
#91238 04/18/2005 9:58 AM
Okay guys here's a new one for you. I have a tilt column in my 38 with the standard lock-on-start switch. I would like to bypass the start function of the switch and install a push button start switch on the dash (don't ask why, it's just something I want to do.) Anyone ever done this or any ideas on how to do it?
Thanks, Don
#91239 04/18/2005 1:24 PM
Take the purple wire from column switch, run it to one side of push button. You then need to run a hot wire to the other side of push button switch. The purple wire delivers power to the starter solenoid from the switch.
#91240 04/19/2005 12:30 PM
Thanks Oehm Jr.'s for the reply. The hot wire to the other side of switch is just any 12V wire that is hot all the time? Thanks, Don
#91241 04/19/2005 12:44 PM
Yes. Use like a #14 or larger wire.
