3 members (TexasJim50, baldeagle, 1 invisible),
91
Mod | | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91238 04/18/2005 9:58 AM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Okay guys here's a new one for you. I have a tilt column in my 38 with the standard lock-on-start switch. I would like to bypass the start function of the switch and install a push button start switch on the dash (don't ask why, it's just something I want to do.) Anyone ever done this or any ideas on how to do it? Thanks, Don | | |
#91239 04/18/2005 1:24 PM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | Take the purple wire from column switch, run it to one side of push button. You then need to run a hot wire to the other side of push button switch. The purple wire delivers power to the starter solenoid from the switch. | | |
#91240 04/19/2005 12:30 PM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Thanks Oehm Jr.'s for the reply. The hot wire to the other side of switch is just any 12V wire that is hot all the time? Thanks, Don | | |
#91241 04/19/2005 12:44 PM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | Yes. Use like a #14 or larger wire. | | |
