7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Is there some trick or special tool I need to loosen/tighten the front drum brake bleeder screws? I cannot get a box end wrench on them with a bleed hose like I can with the rear drums. I can get a little deep well socket and socket wrench on them but then I can't attach a hose and I have to let the fluid squirt out all over.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Did you try an open end wrench?
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Take it out into the yard/dirt/gravel or put newspaper under, only a small amount comes out if you have two people doing the bleed for those two wheels (This is the main reason for staying married), Then wash off with Brake Kleen or other.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I must say that while a little expensive I do like the Speed Bleeders which, in that case, we don't need the wifey to get dirty. Keep her cooking in the kitchen  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A brake bleeder wrench would be the best tool for this. While a flare nut wrench could work, they tend to be bulkier than a standar box end, and may not clear. Using an open end is sure fire way to round off a bleeder screw.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...nice wrench woog. MY personal pick to start with is a 1/4" drive and a deep socket.....and I have a boxed end wrench that is almost in the shape of a "C" that lets me get most of'em loose. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The wife stays in the truck to operate the pedal, no dirt. He does not have a problem getting it loose, he has a problem with getting a wrench AND hose on at the same time.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I just have a 2man 1 holding his finger over the hole during the up stroke of the pedal. catch the run off in a can. U uually can't re-use it anyway
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Is there some trick or special tool I need to loosen/tighten the front drum brake bleeder screws? I cannot get a box end wrench on them with a bleed hose like I can with the rear drums. I can get a little deep well socket and socket wrench on them but then I can't attach a hose and I have to let the fluid squirt out all over.
Thanks, the worst part is initially breaking the bleeder free in the first place. after that you can use an open end wrench during the process. deep 6 point socket to break it free. one does not need tremendous pressure to seat the bleeder. it just gets frozen from inactivity ron | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Nothing beats a set of speed bleeders.............
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Actually, John T is right, but who has $20?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | good lord.......
the day before you bleed the brakes spray pb blaster, or a 50/50 mixture of acetone and transmission fluid on the bleeders. a line wrench, or 6 point sockets usually works pretty good, but before you try to loosen the bleeders, take a moment to take a small hammer and TIGHTEN the bleeder with a light tap first. yeah... i know. then, again with the hammer, light taps to loosen the bleeder. it sorts of works like an impact hammer, and as long as you don't go stupis rambo with the hammer, usually works. as for gettin a bit of brake fluid on you being a problem, a thicker brand of underwear usually helps.
ok.....ok.... i'll stop.
the key is, lots of penetrating oil, and patience. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Put a piece of clear, flexible hose on the end of the bleeder and the loose end, into a drain pan, beer can or whatever container you choose, to catch the run-off. The clear hose allows you to see the clarity/cleanliness of the fluid and whether there are bubbles present.
