0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For some time I have wondered if the Step drill bits are worth a flip. I've used "uni" bits but never a step drill bit.
I see them come up on "special" at times like now there is 3 of them on sale at Harbor Freight bor 9 bucks and there is 29 steps for drilling.
While I probably would not buy Harbor Freight what do you guys think of them.
Lets hear it.. .and recommendations. | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | I just bought one. It's 1/8 to 1/2 in. I drilled a 1/4in thick piece of steel with it to 3/8 diameter. I did use oil to keep it lubricated. It actually worked very well. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | For some time I have wondered if the Step drill bits are worth a flip. I've used "uni" bits but never a step drill bit.
Lets hear it.. .and recommendations. I have some of those Harbor Freight step bit they work great and if you break one ( which I haven't broken any) they don't cost much to replace
1938 Gmc 1/2 ton
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | I am a skeptic when it comes to these one thing duzitall gizmos. Step bits however work quite well if you do not need precision and remember to stop at the right step.
I have not been in Harbor Freight for several years and do not expect to do so for several more.
Dan Bentler | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I thought unibits and stepbits were same thing? I have the "unibits " and love them as the holes are round and cuts fast.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I thought unibits and stepbits were same thing? I have the "unibits " and love them as the holes are round and cuts fast. They are. "Unibit" is actually a brand name. They're ok if you're drilling in relatively thin material and don't want to pack around a bunch of bits. Personally, I prefer regular bits for most of my drilling, and the Blair Rotabroach hole cutters for anythng I'm doing in sheetmetal, as they leave a burr free perfectly round hole.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I guess in the end it just depends on how thick the piece your drilling in is and how deep you need the exact size hole to be. As you can tell, I have not used them. I'm just trying to learn something here. If you want a hold, say 1/4", and that size is the "second one" up on the step drill bit, how could you drill a 1/8" hole all the way through a 1/2" pice of steel without it drilling a bigger hole at the top??
Am i making sense or just showing my stupidity here on something I've never used?
A fellow gave me a "unibit" once that looks like a "cone" with a hole in it but I've never thought to use it. It just lays in the bit box.
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | Alvin, you can't drill a 1/8" hole in a 1/2" piece of steel with a step bit, unless the 'steps' are spaced 1/2" apart. The bit I have is spaced about 1/4". They are very good on sheet metal. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | They work great in sheetmetal, and I really like them in tight spaces. I use them with a 90 degree attachment on my drill and get into places that would be hard to do without cutting down a bit. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | The cone with a hole in it sounds like a counter sink bit. Good for making flush counter sink screws or oval head screws. | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | Step bits are the only way to go on sheet metal, and that's really what they are for. You don't get the bit catching like regular spiral bits do on thin stuff. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I hear you loud and clear, Wayne. Thanks for the comments guys. I think I'll go ahead and get the 3 piece set as I have some small sheet metal patterns to cut out and use. MNSmith, I think you may be right on this to but I swear I think it says "unibit" on the little plastic tube. I'll have to check the next time I'm out in the shop, tomorrow, if I can remember to take a look.
Alvin | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I actuall have a set of Harbor Freight Uni-bits. They work great. I've had them for about 4 or 5 years. I'm an electrician and I use them all the time drilling out hole in panels. I just recently bought a set of the step bits to try out. I hope they last just as well. You can buy about 4 sets of the HF bits for the price of a Greenlee or Irwin bit. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | "Unibits" are designed for sheet metal, and I understand they work great. I bought one 20 years ago, and have done a lot of metal work, but never tried it! Guess I just use my old stuff...
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | It has been and continues to be the one of kind excellent bit that seems to work when others just won't do. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | just bought a set of three titanium step drill bits at the local flaps on sale for 29.95 atd tools made in china though. think i got a great price considering the other locals want that for just the one. i know hf is cheaper but just cant bring myself to buy from them. haven't tried them yet but i hope they work well. later MO
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Yo big 'Chippie!
I HAVE that Harbor Freight set cause I needed one on a Sunday and they were close. I also have a $60 1/8 - 5/8 one. I use 'em all a lot. I can't tell any difference in how they cut! Buy the cheapies and see if you like 'em. If you don't, no biggie, but if you do get a real good one! I keep one in mt 18V Dewalt all the time.
Les | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have the HF stepped drills and they work great. Didn't use them for awhile at first because I thought they were only for sheet metal. Drilled holes in my 57 frame for brake hoses. Perfect.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | Had very good luck with HF step bits on sheet metal | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | tried my cheap step drill bits and love them. wish i would have bought them years ago. very handy and do a nice job. actually going to find some bigger ones. later MO
| | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Sheet metal for sure, works great. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Alvin I finished my roller gate a few months back and used step bit a lot on 11 gauge. 2x2 square tubing to bore rosette weld holes in it when I was piecing shorter sections together with internal bracing. Very useful.
R-Bo
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks R-Bo. I think I've really tried to use the bits on to thick and to tough of material.....something for which the ones I got probably are not intended for? I've still got them and will give them a second chance on some other stuff. Thanks for chipping in. | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I use them a lot at work, on anything less that 0.100". The key to using them, and not destroying the edge, is to slow down the drill as you get to bigger and bigger steps. I have seen many people destroy a uni-bit by trying to drill a 3/4" hole on high speed. Usually all that happens is you will work harden to metal, and dull your bit.
Another consideration is to see which edges are sharp. You can buy some bits that have two cutting edges, so once one edge dulls you can reverse the drill and you have a brand new bit. The reason you can do this is because a uni-bit does not have spiral flutes, just a strait channel.
