1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hi Folks,
I've done a search, but did not find what I'm looking for.
I've got window regulator replacement roller kits (CP 18-795). Removing the old shafts seems simple enough (drill out/off stake and push out). However, what is recommended procedure for staking the new shafts? Peening with a hammer? Press in a vise? Do I need a large radius tool for the stake?
Beyond that, can anyone provide some advice on pitfalls to avoid or how-to tricks?
Please advise and many thanks for the help.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bill, is these what your using? http://www.classicparts.com/1947-63-Window-Regulator-Rollers/productinfo/18-795/If so here is MY experience with them so take it for what its worth. When I put these new rollers in I found that when I ground off the back, and knocked the old ones out, that the hole that was left was to BIG for the new rollers stem. I then had "stems" specially made by a bolter friend to fit the hole in my regulator arm but still used the plastic rollers. **what I should have done was grind the old stems flat and NOT punch them out. With them ground flat I could then center punch/mark the center and then drill a hole the size of the new ones I received...put the new ones in and then peened them a time or two to make sure they hold in place. Hope all this makes sense?! The current repops may now have the right diameter "stem" but I would not bet on it. If you have any questions maybe we could discuss it over some BBQ at Charlies or here at my shop. I have an extra one on hand.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | New ones do fit pretty good. I did like you, grind the back then just wiggled out the remainder. I put the new one in, took a chisel and gently gave a whack to back side of the stem. Turned the chisel 90 degrees and gave another gentle whack. Everything seemed nice and tight. Time will tell! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | MNSmith, Thanks, I'm glad to hear they are now correct. I have s couple of the rollers with the wrong size stem in them and an old regulator I was going to repair for a spare rather than through it away. When I do this I will try to remember to show a picture of my delema back when I put mine in....probably 2 years ago. Thanks again. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The original regulators did not use a roller, it was just a stepped post the slid on the channel. One washer was inside the channel and the other out side. The leather washers kept the post in it's proper location in the channel, held the lubrication and kept it from rattling. http://www.pbase.com/dennygraham/1950_doors&page=all To set the new posts I used a ball bearing and a hydralic press. http://www.pbase.com/dennygraham/image/120007835 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...Denny, well done and well said. I remember the leather washer discussion back when I did mine but for some reason I figured the plastic roller would be as good, maybe last a bit longer, than the leather. I'm happy with the rollers and my windows work great but it sure threw me when the repop stems were to small and I had already driven out the old studs.
..and a big thanks to you Denny for all the work you've done. I know a lot of bolters look at your work and I have certainly told my share of folks to check out your work to get answers. Thank You.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I second that, Denny!!
I'll have to look for my old studs to see if they were the originals. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No one is reproducing the original style studs. The ones I show in my album are ones that I made on a 6" Logan engine lathe I had in the basement.
I looked into having a batch of true to original ones run off at a local machine shop on a CNC turning center but the cost to program it turned out to be to much for a short run. Besides marketing them to recoupe the investment becomes a problem in that we can't mention that we have them for sale in the most popular forums like here, and the word gets lost in a day over in the sparsely visited Swap Meet forum. I went thru that exercise when I had a bunch of vinyl paint stencils made up for the "Thrift Master" logos, still stuck with a bunch of those.
But if one is interested in having their windows roll up like they did when the truck was new, an accurate reproduction of the original parts can be made if you have access to a small bench lathe. The dimensions for the posts and washers are posted in my album. Denny Graham Sandwich, IL
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Alvin, Denny, and MN,
Thank you for your help. I'm less intimidated by this project now.
Never, never, never, never give up. - Churchill | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | Alvin I got the same roller replacement kit from Classic. Before I jump into the deep end I want to confirm you are saying I need to grind off the "shiny" end cap of the current window roller. If I understand once I do that, I should leave the old sleeve in the regulator arm and insert the new wheel. Let me know if I am on the right path. Window roller connection at regulator | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | Alvin The replacement roller kit from Classic fit the hole in the regulator perfectly. The manufacturer must have figured this out and modified the part. Slipped right in and was pretty easy to crimp and peen over on the inside. Replacement in regulator arm New window roller side | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...Bob, at least we can now say a vendor DID correct a mistake. Glad it worked smooth for you. | | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | so does both rollers go inside channel or one outside one inside on the plastic rollers
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The roller straddles the outside lip of the rail. Carl
| | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | | | |
