| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | If I removed the road draft tube and placed a PCV valve in a rubber grommet there instead, would their be too much oil splash for it to work properly. The air would enter through a filtered cap in the valve cover. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I cut the down tube off of mine and found a PVC valve with a rubber gromet that came very close to that tube size. Just a little adjustment with a razor it fit perfect. I can dig up the NAPA PVC numbers if you want them.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Numbers and pictures would be be great. Bob Giles | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | I can dig up the NAPA PVC numbers if you want them. I would like to see that as well | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | Here is where I picked up the vacuume and here is my PVC valve. NAPA # 2-9208. I was told that this may not be the correct valve due to it is not spring loaded and should be upright. I will have to figure out if I need a different valve.
