1 members (baldeagle), 56 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#909502 01/07/2013 3:11 PM
If I removed the road draft tube and placed a PCV valve in a rubber grommet there instead, would their be too much oil splash for it to work properly. The air would enter through a filtered cap in the valve cover.
Bob Giles #909506 01/07/2013 3:28 PM
That might be too close to the splashing oil in the pan/lower-block?
You could place the valve near the top of the road draft tube as was done by GM.
Bob Giles #909769 01/08/2013 1:13 PM
I cut the down tube off of mine and found a PVC valve with a rubber gromet that came very close to that tube size. Just a little adjustment with a razor it fit perfect. I can dig up the NAPA PVC numbers if you want them.
If you never tell a lie, you never need to remember what you said.
Bart_Bosco #909772 01/08/2013 1:29 PM
Numbers and pictures would be be great.
Bob Giles
Bart_Bosco #910370 01/10/2013 1:59 PM
I would like to see that as well
Bob Giles #910616 01/11/2013 1:03 AM
Here is where I picked up the vacuume and here is my PVC valve. NAPA # 2-9208. I was told that this may not be the correct valve due to it is not spring loaded and should be upright. I will have to figure out if I need a different valve.
