2 members (baldeagle, dunfire), 50 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#909826 01/08/2013 4:31 PM
looking for the best way to run my fuel lines from fuel pump to carb. The easy pathway looks to be from fuel pump up the front of the block behind the alternator across the top of the intake and into the carb. I have a 1977 chevy stepside with a 350. will running the fuel lines that close to the block and the intake cause heat issues for the fuel lines? maybe vapor lock? whats the vote on metal vs rubber fuel lines. I have a 350 with edelbrock proformer intake and edelbrock 4bbl 650 carb, any suggestions on a good fuel filter? Paul
wodniw5 #909837 01/08/2013 5:31 PM
the route you suggest is factory, just make sure to stand the line off slightly so there's no direct contact anywhere - which is easier to maintain with metal than rubber .... the carb should have a fine screen insert in the inlet fitting, but I've always used the cheap see-thru plastic filters just before the carb with no problems
wodniw5 #909842 01/08/2013 5:47 PM
Edelbrock carbs need an inline filter.They make a hard line fitting that that connects to the carb,has a cleanable filter.This fitting ends at the front of the manifold.Go on line to Jegs.They have list and pictures on Edelbrock parts.Please use a minimum of rubber line.
wodniw5 #909883 01/08/2013 8:20 PM
I'm not a big fan of rubber hose.
wodniw5 #910009 01/09/2013 9:32 AM
thanks, advance auto has a fuel filter line kit for edelbrock, guess I will try that.
wodniw5 #910080 01/09/2013 1:07 PM
whats the difference in single feed line and dual feed line fuel lines? is there any difference in performance. the single feed is 40.00 and the dual is 90.00.
wodniw5 #910102 01/09/2013 1:51 PM
the dual feed is for the "Thunder"series carb which has two inlets.
The standard Performer carb is single feed.
wodniw5 #910112 01/09/2013 2:18 PM
i have the thunder series and you can run it single or dual, any advantage to running dual vs single
wodniw5 #910167 01/09/2013 5:19 PM
i bought a fuel line kit from edelbrock..hard line from carb to a filter to braided steel with an fittings to the pump did have to find a adapter for the an fitting at the pump....i like it i think its a nice set up.. this here ...dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
wodniw5 #910183 01/09/2013 6:04 PM
Thanks, does anyone know if their is an advantages to running dual feed vs single feed?
wodniw5 #910185 01/09/2013 6:13 PM
Dave nice set up. I like the braided line idea fro the pump, less bending and it looks nice
