| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | looking for the best way to run my fuel lines from fuel pump to carb. The easy pathway looks to be from fuel pump up the front of the block behind the alternator across the top of the intake and into the carb. I have a 1977 chevy stepside with a 350. will running the fuel lines that close to the block and the intake cause heat issues for the fuel lines? maybe vapor lock? whats the vote on metal vs rubber fuel lines. I have a 350 with edelbrock proformer intake and edelbrock 4bbl 650 carb, any suggestions on a good fuel filter? Paul | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the route you suggest is factory, just make sure to stand the line off slightly so there's no direct contact anywhere - which is easier to maintain with metal than rubber .... the carb should have a fine screen insert in the inlet fitting, but I've always used the cheap see-thru plastic filters just before the carb with no problems
Bill | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Edelbrock carbs need an inline filter.They make a hard line fitting that that connects to the carb,has a cleanable filter.This fitting ends at the front of the manifold.Go on line to Jegs.They have list and pictures on Edelbrock parts.Please use a minimum of rubber line. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I'm not a big fan of rubber hose. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | thanks, advance auto has a fuel filter line kit for edelbrock, guess I will try that. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | whats the difference in single feed line and dual feed line fuel lines? is there any difference in performance. the single feed is 40.00 and the dual is 90.00. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | the dual feed is for the "Thunder"series carb which has two inlets. The standard Performer carb is single feed. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | i have the thunder series and you can run it single or dual, any advantage to running dual vs single | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i bought a fuel line kit from edelbrock..hard line from carb to a filter to braided steel with an fittings to the pump did have to find a adapter for the an fitting at the pump....i like it i think its a nice set up.. this here ...dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Thanks, does anyone know if their is an advantages to running dual feed vs single feed? | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Dave nice set up. I like the braided line idea fro the pump, less bending and it looks nice | | |
