1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Never found any used inside sun visors so I ordered some new brackets and visors from a vendor....well, I didn't have but one so I just ordered a new set.
Question: I know the arm of the bracket have a couple little "tabs" that keep the visor part from going to far toward the end of the bracket where it bolts to the overhead.....What I want to know is how do you control (tighten or losen") the visor itself to keep it from slipping off the open end of the bracket. My guess is that you have to "squeeze" it on the bracket rod a little to keep it tight.
Any thought? I'm listening.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | When I have push the visor onto the bracket it was extremely tight and I wished they were just a tad looser. Because it is tough to move the visor.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I oiled the new ones I bought for my one ton to slide them on; as Dennis said, they're a tight fit.
I need to buy some for my panel, just so I can put my old GM service mirror on, but so far I've been too cheap. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think you guys are correct. I'm fairly sure its a "press" fit and as they got loose farmers would simply "squeeze it a bit" and tighten it up. Heck, I've got an old one that someone put a bolt through close to the rod and tightened it up!!
I think I'm good to go. I was just seeking some info that perhaps would help. I'll get the grease cup out... | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'm all ears, still using my hand to shield the sun. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Alvin -
My gut feel is that you bend the rod a tad to make the visor fit tighter. Probably easier to bend before mounting to the truck. I mounted my reproduction visor about 13 years ago. I still need to tweek the fit. It has a tendency to flop down a little at 30mph.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I installed new ones about a month ago and was afraid I was going to ruin the visors trying to get them on the rods. They are so tight I don't try to adjust them while I'm driveing. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | I had the same problem with my aftermarket inside visors. I don't think quality control is a word that even excist in the Chinese language. The fit was hideous. The solution was to remove all the rivets & crappy visor,slightly pry open the part that holds the visor just enough to drop a small washer spacer in between. Using the crap cardboard visor previously removed,cut a nice new visor from real 1/8" plywood.Sand the shaft with 1500 sandpper,little bit of vaseline. Install new rivets, now they work fine. Hope this helps you guys with yours. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Everyone's right - the fit is waaaay too tight. I pulled mine off of the rods, sanded the rods down a bit then put some oil on them. They work fine now - except that the visors kept swinging out away from the roof visor. I added a couple of small hooks so I can hook the visors in place when not in use.
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I know they're not stock, but I got 2 new (in the box) 2009 Buick Enclave visors and installed them in my 51 panel. Both have lighted vanity mirrors ( I wired them up) & they articulate pretty well side to side and up and down.
These were units that were either over runs or discontinued due to engineering changes. In any event I'm happy with them. Got em off eBay for 45 bucks.
The screw in base pattern is slightly different from stock but is still 3 holes. You just need to orient the bases so the visors articulate properly.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ...except that the visors kept swinging out away from the roof visor... Mine do that too. | | |
