3 members (MRMEROTH11, delwrench, 1 invisible), 69 guests, and 4 robots.
Topics128,190
Posts1,057,223
Members48,465
On my 1947 COE (46 style):
I have a 1960 engine (235) from a pickup that has a 10" clutch disk. The original engine (235) from the COE has a 10 3/4" clutch.
I'm putting in the 1960 engine and am planning on using the clutch that came with it. Will there be any reason that I should try to use the bigger clutch? I'm thinking that if the 10" clutch worked with the engine in a pickup, putting it into a COE with the same engine shouldn't really change anything. Am I right or out in left field?
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
Will your COE weigh the same as the pickup? If not you may want the larger clutch to prevent slipping...especially if you plan on towing or carrying anything.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
