0 members (),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 1 New Guy | | New Guy Joined: Dec 2012 Posts: 1 | I just got a 1956 3100 with a 350 small block, and i want to put headers in it. I bought full length Hooker Headers that summit racing claimed would fit but the steering shaft gets in the way. Any suggestions on which headers i should use? Thank you | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Go to the "Links" page,check-out the exhaust section,and you should be able to find your answer. There's one shop,(don't remember the name), on there that uses p.v.c. tubing,as a mock-up tool.Pretty cool video! Hope this helps. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | On the AD trucks, I've always hed to use block huggers. For those with Camaro clips, Sanderson makes a modified block hugger. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I have a set of 350/400 block huggers I'll let go of cheap. Picked em up new from Summit for my Stingray but I sold the car before they ever went on. PM me if you're interested. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Chevy Ram Horns have good flow and look good. They run up to 2 1/2" on Corvettes. Nice fit and A/C mounting. They don't leak! Craigslist, Ebay or Stovebolt. The diff between those and headers would only be about 2-5 HP on a stock 350. There is a pair on my Craigslist (Phoenix) right now for a mid 70's Corvette, $40. Search: ram horn to see what they look like. There is no way of knowing for sure if a pair of manifolds fit with a certain engine swap until you try them. Each swap has a little different engine location. Most V8 exhaust manifolds, headers or otherwise, in TF trucks are very close to the steering box.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2011 Posts: 33 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 33 | I used a set of 65-85 1/2 ton 1 5/8 tube full length headers years ago in a 56 3100. Had the stock front mounts, and cleared everything. I think they were a cheap set of headmans - all I could afford at he time - I think I actually got them at Auto zone. The only thing was that the collectors pointed down slightly - not a problem on the dragstrip ( SMILE) but a pain to hook up a street system to.This was 84 when I was running on a high school budjet. LMD | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Or... [IMG] http://i664.photobucket.com/albums/vv9/axeimen/Route%2066/downsize18.jpg[/IMG] C4 Corvette shorty headers. Found them for $10 bucks at a swap meet. Took the heat shields off and wrapped them. Turned them upside down to clear the power steering box. Bought a bunch of 2.5" mandrel bends from Summit racing and welded up a dual exhaust system, which exits in front of each rear wheel. It's wrapped so that things don't start melting in the engine bay. Looks a little odd, but it works very well. By the way, this is a Chevy 283. Rochester Quadrajet carb. With 3.50 gears in a Dana 60 rear and the original SM420 transmission, it gets 20 mpg on the highway.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
