4 members (Hotrod Lincoln, Hanks custodian, Uncles51, rfs56trk), 106 guests, and 3 robots.
Topics128,128
Posts1,056,666
Members48,450
I have a '56 235 with a short water pump, but have only 1" from the pump nose to the radiator. The pusher fans installed are not cooling enough in 50 deg. weather. I have a 185 thermostat and it is working. The engine is a fresh rebuild, and has only run about 2 hours. I have a new aluminum radiator from Champion, made for the straight six, however, there are tranny oil cooler ports at the bottom, that makes me thinks it is a universal (6 or 8). The radiator is installed at the back or the radiator support, and there doesn't seem to be a more forward set location available. How can I possibly install a fan and clutch, for a 235 engine that has been installed in the original mount location?
Wes
I don't think a 235 ever came with a fan clutch. Are you driving down the road and getting hot or sitting still and having cooling problems?
A fresh rebuild will have more friction and tend to run hotter.
Make sure you have it timing advanced enough.
When you say short shaft I assume you mean a modified long shaft pump. They can work OK but are not the best for cooling.
My Blog
Originally Posted by Pre '68 Dave
...I assume you mean a modified long shaft pump. They can work OK but are not the best for cooling.
I'll second that. I ran a short pump in my 1 ton for years and it was just marginally OK at cooling.
Had I known then about the water pump adapter plate I would have used one then and recommend that you use one now.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
