1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 22 New Guy | | New Guy Joined: Dec 2009 Posts: 22 | I have a '56 235 with a short water pump, but have only 1" from the pump nose to the radiator. The pusher fans installed are not cooling enough in 50 deg. weather. I have a 185 thermostat and it is working. The engine is a fresh rebuild, and has only run about 2 hours. I have a new aluminum radiator from Champion, made for the straight six, however, there are tranny oil cooler ports at the bottom, that makes me thinks it is a universal (6 or 8). The radiator is installed at the back or the radiator support, and there doesn't seem to be a more forward set location available. How can I possibly install a fan and clutch, for a 235 engine that has been installed in the original mount location?
Wes | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I don't think a 235 ever came with a fan clutch. Are you driving down the road and getting hot or sitting still and having cooling problems? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A fresh rebuild will have more friction and tend to run hotter.
Make sure you have it timing advanced enough.
When you say short shaft I assume you mean a modified long shaft pump. They can work OK but are not the best for cooling.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...I assume you mean a modified long shaft pump. They can work OK but are not the best for cooling. I'll second that. I ran a short pump in my 1 ton for years and it was just marginally OK at cooling. Had I known then about the water pump adapter plate I would have used one then and recommend that you use one now. Grigg | | |
