1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#90877 05/11/2003 7:42 PM
Junior Member
Junior Member
I've just tried installing an aftermarket turn signal kit on my '53 1/2 Ton. The signals work great until I turn on either the parking lamps or the lights. When I pull the light switch on, the signals switch off. What did I do wrong?
#90878 05/11/2003 8:00 PM
Where did you get the kit? Thanks!
#90879 05/11/2003 8:28 PM
Junior Member
Junior Member
I picked it up from Chevy Duty, PN#53-551, it is supposed to wire directly into their wiring harness. I'm sure it does but I probably crossed the wires somewhere.
#90880 05/11/2003 9:19 PM
Redundant ground wires are your friends. wink It sounds like the power is being shunted off the signal switch when the headlights are on; perhaps you selected the wrong tab on the headlight switch to tap the signals? If all else fails, you may want to run a dedicated hot lead off the ignition switch to isolate the turn signals.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#90881 05/12/2003 2:33 AM
Junior Member
Junior Member
Thanks a bunch, I found the problem. I was running the signal wires to the smaller contact line. The lights were working but I couldn't tell because the other filament was drowning them out.
