| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Hey all. I keep having this crop up on my 54 3100. Step on starter and it cranks slow, almost like battery is low. Sometimes the first time I start it and sometimes after I've driven it, stopped somewhere and gotten back in to leave. The other day stopped for gas, went to leave and tried several times to start. Thought I'd killed the battery. Called a buddy to come jump the truck and while waiting tried it one more time. Spun over with lots of power and fired right up. 6v system with 8v battery. I'm gonna clean all the connections and was wondering if there's anything else I should check. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If the cables are the proper size and all connections are clean it should work fine with a 6V battery. Make sure it doesn't have tiny 12V cables. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Make sure all the grounds are good. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Cletis. What size should the cables be? PO put the 8v battery in. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Original 6v battery cables were supposedly 2 gauge (12v cables are usually 4 gauge). Use battery cables of 1 gauge or fatter (0 or 00 are better - also called 1/0 or 2/0)
Using an 8v battery temporarily avoids the real problem (problems), and the 8v system might decrease the life of 6v bulbs.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Bad battery, get a new 6V and your troubles will be over.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I'm having the same issue (6v system and battery) ... turns out the starter needs a rebuild.
Once you clean everything up, consider running the proper battery. Mine came with an 8v and ran better when I went back to a 6v. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks to all for the input. Saturdays project will be cleaning/replacing cables and attachment points. I'll let everyone know what happens after that. | | |
