4 members (rick46ia, Hotrod Lincoln, Otto Skorzeny, 2-Ton), 101 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
#908025 01/01/2013 7:53 PM
Hey all. I keep having this crop up on my 54 3100. Step on starter and it cranks slow, almost like battery is low. Sometimes the first time I start it and sometimes after I've driven it, stopped somewhere and gotten back in to leave. The other day stopped for gas, went to leave and tried several times to start. Thought I'd killed the battery. Called a buddy to come jump the truck and while waiting tried it one more time. Spun over with lots of power and fired right up. 6v system with 8v battery. I'm gonna clean all the connections and was wondering if there's anything else I should check.
If the cables are the proper size and all connections are clean it should work fine with a 6V battery. Make sure it doesn't have tiny 12V cables.
Make sure all the grounds are good.
Cletis. What size should the cables be? PO put the 8v battery in.
Original 6v battery cables were supposedly 2 gauge (12v cables are usually 4 gauge). Use battery cables of 1 gauge or fatter (0 or 00 are better - also called 1/0 or 2/0)
Using an 8v battery temporarily avoids the real problem (problems), and the 8v system might decrease the life of 6v bulbs.
Sir Searchalot
Sir Searchalot
Bad battery, get a new 6V and your troubles will be over.
I'm having the same issue (6v system and battery) ... turns out the starter needs a rebuild.
Once you clean everything up, consider running the proper battery. Mine came with an 8v and ran better when I went back to a 6v.
Thanks to all for the input. Saturdays project will be cleaning/replacing cables and attachment points. I'll let everyone know what happens after that.
