| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 20 New Guy | | New Guy Joined: Feb 2008 Posts: 20 | I read the tech pages about the install of a T5 tranny in a AD truck. But as far as I can tell (read) it doesn't splain if the shifter floor hole is the same or if I'll need a flat floor panel for a new hole ? Does that make sense?. This is going in a 1950 1/2 ton w/a 216 and open drive line I'm running a 12 bolt rearend out of a 67 1/2 ton. Thanks for any help. Dave | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Yes,you will need the flat floor pan for a three speed on column truck. floor pan you will then need to cut the hole for the t-5 shifter.I installed my t5 without the shifter attached and marked where to cut from underneath the truck with a sharpie marker. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | I think freak means he had a 4 speed with the torque tube before and now has a t5 correct? I think if you used a sm420 it the same but any other four speed (or the t5) might be diffrent.
Id use card board to mock where i was gonna cut, then cut a trans pan from a column shift car if it dosent fit the one you have now
| | | | | Joined: Feb 2008 Posts: 20 New Guy | | New Guy Joined: Feb 2008 Posts: 20 | As of now I'm run a sm420 with a open drive line and I plan on installing the t5. I have a plain cover for a column shift truck. I was hoping I wouldn't have to cut into the floor, just the cover plate. It sound like it won't be to hard to mark and cut. Thanks for the help!. Dave. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | All you have to do is cut a hole in the 3speed transmission floor pan cover.
I wouldn't cut the 4 speed transmission floor cover,they are heavily sought after.
