5 members (Tronman, Phak1, 32Fordpuchoptop, Ponchogl, k2handyman), 88 guests, and 2 robots.
Topics128,042
Posts1,055,520
Members48,424
#906499 12/27/2012 10:24 AM
I read the tech pages about the install of a T5 tranny in a AD truck. But as far as I can tell (read) it doesn't splain if the shifter floor hole is the same or if I'll need a flat floor panel for a new hole ? Does that make sense?. This is going in a 1950 1/2 ton w/a 216 and open drive line I'm running a 12 bolt rearend out of a 67 1/2 ton.
Thanks for any help.
Dave
Yes,you will need the flat floor pan for a three speed on column truck. floor pan you will then need to cut the hole for the t-5 shifter.I installed my t5 without the shifter attached and marked where to cut from underneath the truck with a sharpie marker.
Tim
1951 3100 Chevrolet
I think freak means he had a 4 speed with the torque tube before and now has a t5 correct? I think if you used a sm420 it the same but any other four speed (or the t5) might be diffrent.
Id use card board to mock where i was gonna cut, then cut a trans pan from a column shift car if it dosent fit the one you have now
As of now I'm run a sm420 with a open drive line and I plan on installing the t5. I have a plain cover for a column shift truck. I was hoping I wouldn't have to cut into the floor, just the cover plate. It sound like it won't be to hard to mark and cut.
Thanks for the help!.
Dave.
All you have to do is cut a hole in the 3speed transmission floor pan cover.
I wouldn't cut the 4 speed transmission floor cover,they are heavily sought after.
Tim
1951 3100 Chevrolet
