1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#904309 12/17/2012 8:24 PM
The mirror bracket that is sold here:
http://www.classicparts.com/1947-53-Inside-Mirror-Bracket/productinfo/57-006/#.UM_FXG99J14
How does it attach? I have the extra hole towards the top of my center strip but nothing is threaded...
'53 Chevy truck 1/2 ton
....put a "jam nut" behind it.
Leo Offline
Moderator
Moderator
That bracket can work, but the correct bracket is a round stem with a curve in it with a threaded end. As Alvin says, a jam nut on the back of the centre strip.
So originally all it had was a jam nut? I thought this bracket was used since they list it for those years...
My 50 has a threaded hole in the center bar for the rear view mirror
...pic...
...pic...
Not sure if your 53 is set up the same way.
I don't have a pic, at least not yet, but I have two of the orignal mirrors with the crooked stem. However, my middle piece does not have the hole as dads50. I am almost certain my panel was all original sooooo, the mirrors were just thrown in the box of spare parts....or the clip was used to mount in a regular screw hole but still used the same stemed mirror....
Perhaps the "clip" was an option that dealers used to install an original mirror....or something like that. Its been a long day!!
Original mirrors
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0263.jpg
kevmor99 did you get your mirrow mount worked out?
dbum
Moderated by  ndkid275, Phak1
