1 members (keithfielder),
99
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | At some point a PO swapped out the rear on my 54. Looks like they also modified the mounts. The rear looks much like the one on my 55.1. I put some pics online (link below) and was wondering if anyone can help ID it. There is a small tag screwed in on the drivers side and look like it has 139 stamped on it. Thanks as always. http://s1162.beta.photobucket.com/user/miami54hydramatic/library/rear%20end%20on%20the%2054 | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Don't know about numbers on the tag. Here is the location of the number on a 1954 rear axle. > 1954 Shop Manual> 1954 Rear Axle Serial NumbersHere is the number on the rear axle in my '54 3104. Looks like a previous owner replaced the '54 with one that was built at the Detroit plant on Dec 12, 1950. > Rear axle in my '54 (H E1 212) > 1950 Rear Axle Serial NumbersEach model year has a different serial number designation. Find the number. I'm sure that we can decypher it.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks Lonnie. I'll crawl back under tomorrow and see if I can locate the number. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The center section you have is from a 1955 2nd series through 1962. Most likely a 3.9 ratio.
See the USA in your vintage Chevrolet! My Blog | | |
