2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
At some point a PO swapped out the rear on my 54. Looks like they also modified the mounts. The rear looks much like the one on my 55.1. I put some pics online (link below) and was wondering if anyone can help ID it. There is a small tag screwed in on the drivers side and look like it has 139 stamped on it. Thanks as always.
http://s1162.beta.photobucket.com/user/miami54hydramatic/library/rear%20end%20on%20the%2054
Don't know about numbers on the tag.
Here is the location of the number on a 1954 rear axle.
> 1954 Shop Manual
> 1954 Rear Axle Serial Numbers
Here is the number on the rear axle in my '54 3104. Looks like a previous owner replaced the '54 with one that was built at the Detroit plant on Dec 12, 1950.
> Rear axle in my '54 (H E1 212)
> 1950 Rear Axle Serial Numbers
Each model year has a different serial number designation. Find the number. I'm sure that we can decypher it.
- Lonnie
My '54 3104
Thanks Lonnie. I'll crawl back under tomorrow and see if I can locate the number.
The center section you have is from a 1955 2nd series through 1962.
Most likely a 3.9 ratio.
My Blog
