| | | Forums66 Topics128,115 Posts1,056,624 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 19 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 19 | Does anybody know where I could get some tech information on a Schwartz pto driven hydraulic hoist. I have one under my one ton. I specifically need to know what kind of oil to use in it. It was low, so I put modern hydraulic fluid in it, but now it works even less good, so assume I have the wrong oil in it. I plan to drain it all, and don't want to play the "hit and miss" game with replacement oil. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Schwartz hydraulics are still being built and they still use the same hydraulic oil as 50 years ago. Your pump may just be worn out or the bypass valve may be weak. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | FWIW I am pretty sure that Schwartz is no longer in business. Their product was primarily sold to the farm market and implement dealers. I haven't been able to find a listing for them and haven't seen one for many years. Someone may have purchased it and producing it under a new name. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Schwartz has been through several buyouts, but it still uses the same basic design. http://parkhurstmfg.com/ | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Parkhurst... well then I am right. Parkhurst is 98% a thing of the past. Rob died a few months ago and the last time I was there there was only an empty building at the old plant, doors wide open and birds taking over. I didn't go top plant 2. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Schwartz and later Parkhurst was very popular in Texas for many years. However bob tail field trucks are a dying thing. Combines are big enough to load semis these days. And there is very little grain in Texas any more. Its all cotton. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yes, some combines have 600+ bu. hoppers. Everyone has gone to semi's and getting hard to find a quality grain body builder or any consequence. | | |
