| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | Anyone have a picture or diagram of how the hand throttle attaches to the throttle at the carb? I see the clamp on the carburetor but I am not sure where it goes after that. Thanks | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the wire on the throttle cable goes through the hole in the carb lever linkage with a cable stop on the other side it is the wire that holds the linkage onto the carb. (instead of a clip or cotter pin) It doesn't look like it should work, but it has for 60 or so years. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What are you working on? ...carter... ...pic... | | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | Wow thanks for the quick response! Picture says it all. 1951 Chevy 3600 with a carter. Happy Christmas! | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | I have another question, I hooked up the throttle as shown but as soon as you pull the throttle out, and let it go the linkage spring pulls it rate back. My point is that if you are going to use the throttle to idle the engine up during a cold start the and unless you hold it out it will go rate back to no throttle when you let it go. Is this how it is supposed to work?
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | One final question to DADS50, what is that clip I see in your picture on the linkage arm where it attatches to the throttle arm? Thanks for the help
God bless,
Dave
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | My guess: the original cable was heavy stiff wire and a tight fit in the sheath (like H-D throttles). | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The clip was on the carb when I got it. try your local auto parts that have DORMAN supplies Rock Auto ...click... Im not sure if that Dorman kit 41016 has the correct part but might be worth a try. I got one from a rebuild kit I purchased from carbking. My hand throttle also returns. I'm using a new return spring that may be to strong. I don't have an original cable, using a repo. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't have the return problem with my '38 & the W1. You might try putting a bit of a bend in the wire just outside of the cable housing. When you pull the wire into the housing it'll create a bit of friction to hold it in place. It might take a bit of experimentation to get it exactly right.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I have the same problem, but it sticks enough to raise the RPM up to about 2000 rpm which works well enough for anything I need. I do know the choke cable has been on there for at least 30 years, I don't know if it is original or not, but it works fine. It is hard to pull out as well, (but not real bad) I can't decide if the new reproduction throttle cable is really good cause it doesn't bind up. Or really bad because it doesn't bind up.....I been thinking about crimping the sheathing a bit, but since I don't really ever use it, just put it in mostly for looks, (to fill up the hole) It will be just fine, not to mention it seems about a foot too long. It ought to start rusting up here in a year or two anyway. | | |
