0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#906173 12/25/2012 6:28 PM
Anyone have a picture or diagram of how the hand throttle attaches to the throttle at the carb? I see the clamp on the carburetor but I am not sure where it goes after that. Thanks
ski49 #906176 12/25/2012 6:35 PM
the wire on the throttle cable goes through the hole in the carb lever linkage with a cable stop on the other side it is the wire that holds the linkage onto the carb. (instead of a clip or cotter pin) It doesn't look like it should work, but it has for 60 or so years.
ski49 #906178 12/25/2012 6:49 PM
What are you working on?
...carter...
...pic...
DADS50 #906179 12/25/2012 7:04 PM
Wow thanks for the quick response! Picture says it all. 1951 Chevy 3600 with a carter. Happy Christmas!
ski49 #906265 12/26/2012 9:22 AM
I have another question, I hooked up the throttle as shown but as soon as you pull the throttle out, and let it go the linkage spring pulls it rate back. My point is that if you are going to use the throttle to idle the engine up during a cold start the and unless you hold it out it will go rate back to no throttle when you let it go. Is this how it is supposed to work?
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
ski49 #906266 12/26/2012 9:26 AM
One final question to DADS50, what is that clip I see in your picture on the linkage arm where it attatches to the throttle arm? Thanks for the help
God bless,
Dave
ski49 #906290 12/26/2012 10:33 AM
My guess: the original cable was heavy stiff wire and a tight fit in the sheath (like H-D throttles).
ski49 #906298 12/26/2012 11:38 AM
The clip was on the carb when I got it.
Originally Posted by DADS50
try your local auto parts that have DORMAN supplies
Rock Auto
...click...
Im not sure if that Dorman kit 41016 has the correct part but might be worth a try.
I got one from a rebuild kit I purchased from carbking.
My hand throttle also returns. I'm using a new return spring that may be to strong.
I don't have an original cable, using a repo.
ski49 #906309 12/26/2012 2:15 PM
Ex Hall Monitor
Ex Hall Monitor
I don't have the return problem with my '38 & the W1. You might try putting a bit of a bend in the wire just outside of the cable housing. When you pull the wire into the housing it'll create a bit of friction to hold it in place. It might take a bit of experimentation to get it exactly right.
ski49 #906405 12/26/2012 8:31 PM
I have the same problem, but it sticks enough to raise the RPM up to about 2000 rpm which works well enough for anything I need. I do know the choke cable has been on there for at least 30 years, I don't know if it is original or not, but it works fine. It is hard to pull out as well, (but not real bad) I can't decide if the new reproduction throttle cable is really good cause it doesn't bind up. Or really bad because it doesn't bind up.....I been thinking about crimping the sheathing a bit, but since I don't really ever use it, just put it in mostly for looks, (to fill up the hole) It will be just fine, not to mention it seems about a foot too long. It ought to start rusting up here in a year or two anyway.
