| | | Forums66 Topics128,048 Posts1,055,624 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | hey guys Not getting proper oil pressure and no oil to the rocker arms. I just rebuilt this 1958 235 and i know the oil line was deleted in the lifter galley that year and instead ported straight through the head and through a special bolt. Out of all my head bolts that were in there originally, there was only one irregular one, with a grinded side to it. None with a hole. do you think this is my issue? do i need a head bolt with a hole? or do you think its something else? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Originally a 1958 engine would not use a special drilled or grooved head bolt. Did you make sure to use lifters with the annulus/reduced diameter half way up the OD?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Did you have the block dipped,, they did mine on the rebuild and found it clogged and after the dip it was fine
Merry christmas
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | have you studied the actual routing of the oil system in YOUR engine? It isn't a black science, you just have to make sure there is passages going from the pump to everywhere you want oil be. Depending on which version you have. I completely rearranged my oiling system in a 216 to get a full flow filter, and pressure to the rods. You just have to look at it a bit. | | |
