5 members (Forty9, dt235sd, FAST55, Otto Skorzeny, 1 invisible), 81 guests, and 1 robot.
Topics128,050
Posts1,055,754
#905954 12/24/2012 5:42 PM
hey guys
Not getting proper oil pressure and no oil to the rocker arms. I just rebuilt this 1958 235 and i know the oil line was deleted in the lifter galley that year and instead ported straight through the head and through a special bolt. Out of all my head bolts that were in there originally, there was only one irregular one, with a grinded side to it. None with a hole. do you think this is my issue? do i need a head bolt with a hole? or do you think its something else?
gbuck #905984 12/24/2012 7:18 PM
Originally a 1958 engine would not use a special drilled or grooved head bolt.
Did you make sure to use lifters with the annulus/reduced diameter half way up the OD?
My Blog
gbuck #906002 12/24/2012 9:12 PM
Did you have the block dipped,, they did mine on the rebuild and found it clogged and after the dip it was fine
Merry christmas
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #906113 12/25/2012 12:11 PM
This link may shed some light on the drilled bolt issue
http://chev235guy.blogspot.com/search/label/Drilled%20Head%20Bolt
gbuck #906474 12/27/2012 7:02 AM
have you studied the actual routing of the oil system in YOUR engine? It isn't a black science, you just have to make sure there is passages going from the pump to everywhere you want oil be. Depending on which version you have. I completely rearranged my oiling system in a 216 to get a full flow filter, and pressure to the rods. You just have to look at it a bit.
