0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#905894 12/24/2012 1:55 PM
I am about ready to purchase a front disc brake upgrade kit for my 1965 C10 truck and have seen my options available. I am interested in others opinion regarding using a standard master cylinder versus a master cylinder with a booster. Is the additional cost for a booster worth it? Any pros and cons of the two scenarios would be appreciated.
Get the booster, dual master cylinder, & proportioning valve. It's the best way to go. There are many suppliers out there offering the same kits. Find one that knows something about the product and how it functions instead of ones that just push parts across the counter.
Fred
I agree. Running disk brakes without a booster on a full size truck will perform worse than the oem drum brakes, as disk brakes are not self energizing like the drum brakes are.
Bill Burmeister
Thanks for the info guys. I have a 283 V8 in the truck. Where do you tie in the vacuum line that is needed with the booster?
On the base of the carb at the rear there should be a tapped hole with a plug, remove the plug and get a fitting to connect with the hose from booster. If no plug on carb, you can connect to intake manifold, right behind the carb.
Tommy
59 apache 1/2t
261 short stepside
If we can ever shake the big freeze we're dealing with right now, I'm going to pull my 81' into the shop and pull the front crossmember for my 64'. Disc brakes, power steering, and 17 years newer parts. I can have it out and on the floor to see if there is anything that needs attention before I put it in place, and then roll it under and bolt it up. Like Longbox said, I want it all and hope to be able to make Dawg kiss the dash if I have to stop in a hurry. Besides...I'm cheap and all the parts are there for the taking.
dj durant
More pix on Flickr
If the port on the back of the carb and the port on the intake are already being used can I put a "tee" in the intake port and run two vacuum lines from the same port?
yep
Tommy
59 apache 1/2t
261 short stepside
