2 members (Otto Skorzeny, 1955 1 Series), 89 guests, and 4 robots.
Topics128,031
Posts1,055,436
Members48,422
#90549 07/19/2002 6:46 PM
Thought I had all of the electrical issues worked out and now find that the dome light does not work. Verified that it is getting juice and has a good ground, bulb element is brand new. Noticed that the switch was a little iffy. At first it was a solid click when I turned it on but now nothing. Has anyone ever replaced just the switch? Don't have enough change in the ice cream pail for a new light at $42 +/-. frown Saw some similar switches a Radio Shack.
Deaner
1950 Chevy 3600 Stake Bed
I don't know where I'm going, but there's no sense being late!
#90550 07/19/2002 10:28 PM
You might want to post a request in the Swap Meet. It should be a less inexpensive price for a used base/fixture.
#90551 07/20/2002 5:58 AM
You probably have dirty contacts in the switch. If you have any, squirt some electrical contact cleaner in the switch. TV tuner cleaner, R-12, brake cleaner or carb cleaner will work, to. Just don't get the last two on your paint.
Fred
52 3600
69 C-10
#90552 07/20/2002 5:41 PM
dont get it on the plastic lens either
54 3100 with 235
62 flatbed dump C60 with 261
#90553 07/22/2002 5:50 PM
Took mine apart in my '49 1/2T. Got the switch out, pried open the fold down tabs and cleaned everything up well. Switch operates through a small steel ball and if that is gunky it won't always make contact. Put mine back together and its works. Sometimes you need to push the switch down into the socket a little to move that detent ball.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
