| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90549 07/19/2002 6:46 PM | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | Thought I had all of the electrical issues worked out and now find that the dome light does not work. Verified that it is getting juice and has a good ground, bulb element is brand new. Noticed that the switch was a little iffy. At first it was a solid click when I turned it on but now nothing. Has anyone ever replaced just the switch? Don't have enough change in the ice cream pail for a new light at $42 +/-.  Saw some similar switches a Radio Shack.
Deaner 1950 Chevy 3600 Stake Bed
I don't know where I'm going, but there's no sense being late!
#90550 07/19/2002 10:28 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to post a request in the Swap Meet. It should be a less inexpensive price for a used base/fixture. | | |
#90551 07/20/2002 5:58 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You probably have dirty contacts in the switch. If you have any, squirt some electrical contact cleaner in the switch. TV tuner cleaner, R-12, brake cleaner or carb cleaner will work, to. Just don't get the last two on your paint.
Fred 52 3600 69 C-10
#90552 07/20/2002 5:41 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | dont get it on the plastic lens either
54 3100 with 235 62 flatbed dump C60 with 261
#90553 07/22/2002 5:50 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Took mine apart in my '49 1/2T. Got the switch out, pried open the fold down tabs and cleaned everything up well. Switch operates through a small steel ball and if that is gunky it won't always make contact. Put mine back together and its works. Sometimes you need to push the switch down into the socket a little to move that detent ball. | | |
