1 members (Otto Skorzeny),
145
0
Mod | | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 97 | will 41-46 rear fenders from a panel truck fit the pickups? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I don't believe so. They are not as wide. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think the Panel fenders are pretty rare. If you have a set, may be able to trade / sell for a pair of pickup fenders ? | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | My 1 ton uses panel fenders. They are too narrow so the company used what appears to be a 4-6" flat stock bent to match the contour of the fender. The other side is screwed to a lip on the sidewall of the box. Welting is used to transition the two. | | | | | Joined: Nov 2012 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 97 | Thanks for the info and guidance | | |
