0 members (), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,454
#904529 12/18/2012 7:35 PM
will 41-46 rear fenders from a panel truck fit the pickups?
I don't believe so. They are not as wide.
I think the Panel fenders are pretty rare. If you have a set, may be able to trade / sell for a pair of pickup fenders ?
1940 Chevy KC 1/2-Ton
You posted it here too: https://www.stovebolt.com/ubbthread...Main=133815&Number=904685#Post904685
It's best to post only in one area. The fenders are different, but like was said if you have a set of panel fenders you could probably sell them for good money as they're very uncommon.
My 46 GMC on Photobucket
My 1 ton uses panel fenders. They are too narrow so the company used what appears to be a 4-6" flat stock bent to match the contour of the fender. The other side is screwed to a lip on the sidewall of the box. Welting is used to transition the two.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Thanks for the info and guidance
