1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....put a "jam nut" behind it. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | That bracket can work, but the correct bracket is a round stem with a curve in it with a threaded end. As Alvin says, a jam nut on the back of the centre strip. | | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | So originally all it had was a jam nut? I thought this bracket was used since they list it for those years...
'53 Chevy truck 1/2 ton
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | My 50 has a threaded hole in the center bar for the rear view mirror ...pic... ...pic... Not sure if your 53 is set up the same way. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I don't have a pic, at least not yet, but I have two of the orignal mirrors with the crooked stem. However, my middle piece does not have the hole as dads50. I am almost certain my panel was all original sooooo, the mirrors were just thrown in the box of spare parts....or the clip was used to mount in a regular screw hole but still used the same stemed mirror.... Perhaps the "clip" was an option that dealers used to install an original mirror....or something like that. Its been a long day!! Original mirrors http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0263.jpg
| | | | | Joined: Jan 2013 Posts: 20 New Guy | | New Guy Joined: Jan 2013 Posts: 20 | kevmor99 did you get your mirrow mount worked out?
dbum
