Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (farmallb, Peggy M, baldeagle, SandraD, frogfarmer), 46 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#903405 12/13/2012 7:43 PM
I mentioned this problem in another thread a few days ago, but I figure it would easier to start a new thread for a different problem.
I get am getting a knocking noise that is hard to hear when standing over the engine, but it is very prevalent in the cab.
The first video is standing over the engine (idle has been turned down since taking video)
The second video is the from inside the cab.
Some information on the noise, it is there from the second I start it up, until I turn it off. Driving around and letting the engine heat up has no effect on noise.
Thank you for the help in advance.
Have you set your valve tappets per the manual?
What weight oil are you running?
This is the oil burner right?
If your tappets are set right, and your oil isn't super thin, or diluted with gasoline (washing down the cylinders from an overly rich mixture, or shot rings), you might want to drop the oil pan and check the clearances on your con rods, and mains.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
hard to tell over the video. change your oil (don't use synthetic), check rocker lash (when warm). if it's still knocking i'd pull the oil pan..sounds like a rod bearing going out.
This is the oil burner, the weight I am using is 10W-30.
Is there a way to tell if I am getting gas in the oil?
Valves were on the list for this weekend.
I know con rods, what is mains?
all of the journals on your crankshaft have bearings, i.e. 4 main bearings on your main caps and 6 rod bearings on piston rods. If your bearing has failed already your crank or rod is probably scared pretty bad and maybe need to be machined.
Redlegs48 #903439 12/13/2012 10:10 PM
If you are getting gas in the oil, it will smell like gas (alot).
You might want to read the shop manual for the truck. The engine section starts with a description of the engine, and has lots of great diagrams and pictures.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0601.htm
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Redlegs48 #903441 12/13/2012 10:12 PM
Ok... so mains is bearings? I couple of the guys I work with thought it might be a bearing too.
Oil is fairly new, about 50 miles, and it was conventional.
Is rocker lash the same as a valve adjustment? This is what I planned to do this weekend: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0607.htm
I am assuming if I pull the oil pan I am able to see the bearings?
Sorry for all the questions, I just want to make sure I understand everything.
Redlegs48 #903444 12/13/2012 10:20 PM
It sounds like badly out of adjustment lifters.
You may need to reface the rockers to get a quiet end result.
My Blog
Redlegs48 #903455 12/13/2012 10:44 PM
i don't think its your rockers or lifters, i think you've got a bad bearing. If you arn't too mechanically inclined i don't recommend you investigating under the oil pan without someone who is. Just removing the oil pan isn't going to show you too much, the caps need to be removed, and if its not the caps, its your main bearings and that means you have to pull the whole crank. If that's the case a rebuilt might be in your future.
Redlegs48 #903457 12/13/2012 10:48 PM
Bearing noise is almost always affected by engine temperature.
As the oil warms up and the oil thins out they will get noisier.
He stated the noise is the same cold or hot.
I would sure start with the easy job first, adjust the valves.
My Blog
Redlegs48 #903466 12/13/2012 11:14 PM
Hard to really tell over video, but to me sounds like rockers badly out of adjustment. Set you valve lash first. If it quietens down, good on ya. If not, then time to get serious about dropping the pan.
I think the cab kinda filters out some of the quieter rockers and the louder ones are more prominant.
How long has it been sounding like this?
A bad rod bearing will get steadily louder as the engine is run and then fail. If it has been run a good bit without getting any louder, then likely not a rod, though a main bearing can knock a good while. But a main bearing usually has a deeper thump sound to it. I know, not a good description.
But does sound like valves needs adjusting to me. Good luck.
Redlegs48 #903468 12/13/2012 11:26 PM
Sir Searchalot
Sir Searchalot
Before you get carried away. Use a broom handle and touch all over with one end and listen on the other. I don't hear anything on the first video. The inside cab video: I hear an exhaust leak. A stethoscope is nice to have also. HF has them. Yes when they say "mains" they mean main bearings, crankshaft bearings. Yes when you pull the oil pan you can see the bearings.
Redlegs48 #903471 12/13/2012 11:39 PM
I bought the truck a few months ago, sounded like that when I bought it.
I have not seen a visible exhaust leak... where should I be looking?
As for being mechanically inclined, I am pretty good with my hands but I have zero experience with internal combustion engines... I will take a jet engine any day though.
Just to be clear, when I set the valve clearance I keep the engine on?
As for the "thump sound" the video does not do the sound justice. It sounds like someone it hitting the firewall with a rubber mallet.
If you can handle a jet engine, with the right repair manuals you should be able to handle the old six. If you have a friend that does mechanic work, he can help you.
As was suggested you can take a sawed off broom handle and listen to the side of the block to try to narrow dwn where the sound is coming from. Put one end to your ear, the other to the bock just below each spark plug.
If it is a rod bearing, a lot of times if you remove one spark plug wire at a time when you get to the loose rod it will quieten down some. That will be the one that is bad.
When you remove the plug wire, if it doesn't quieten the knock, put the wire back on the plug and go to the next one.
If you pull the oil pan, and look inside th engine, you will see the rod bearing and main bearing caps, but won't see te bearings until you remove the caps.
Sounds are very difficult to describe on the written page or verbally. To one
person it might be a tap, to another it might be a thump, and on and on.
If the engine has a good many miles on it the main bearings are probably worn
and you will hear a dull thump when you first start the engine because the
crankshaft isn't yet supported by the oil pressure. This usually quiets down after
the engine starts and the oil pressure starts to show on the gauge.
There are ways to isolate a loose connecting rod (rod knock) but I would agree
that the best way to isolate where your noise is coming from is with a
stethoscope. This discussion on engine noise is very well done and may help you
. But as is pointed oout even for an experienced mechanic engine noise can be a
tough nut to crack.
http://www.supramania.com/forums/showthread.php?20486-Rod-Knock-Diagnosis-and-FAQ
Unless the truck has had someone that took good care of it and gave it all the
required maintenance over the years you most likely have bad motor mounts
. This usually results in the engine sitting unsupported on the cross member
because the rubber has turned to jelly. That can transfer a lot of the engine noise
into the cab.
As far as setting the valve lash or adjusting the rockers or valve adjustment (all
the same ting) there are a number of instructions here on the ‘Bolt that describe
how to do it with the engine off once it is warmed up. Some people prefer to
adjust the valve lash with the engine running. That is a bit more difficult but it
assures that they are all adjusted at the same temperature. It could take fifteen
minutes to a half hour to adjust them and with the engine off that’s enough time
for the last valve to cool down a lot more than the first one.
Properly adjusted, a valve train with solid lifters will have some high-pitched
metallic sound similar mama’s sewing machine.
Don’t rush into tearing your engine down if it’s got good oil pressure and running
ok. These old Stovebolts will run for a long time even after they are well worn. To
cure your oil burning your only option is to have the engine rebuilt, which will
run you somewhere around 3k.
Denny Graham
Somewhere north of Sandwich, IL
Denny G
Sandwich, IL
I used these instructions when I set my lash with the engine off. (But engine hot after long drive)
...link...
I would really like to see a video of someone setting the lash with the engine running.
I young guy was walking around the nieghborhood and heard my truck running. I had the hood up parked in front of the house.
He asked me whats wrong with my engine.
I told him they just sound like that.
Bad rod bearing makes less noise on rising RPM, more noise on trailing throttle.
Redlegs48 #903537 12/14/2012 12:15 PM
Sir Searchalot
Sir Searchalot
You can't see an exhaust leak unless it smokes and that could be an oil leak. Hard to "feel" it because of the fan. If you're lucky it's an easy mechanical fix, exhaust leak, vibration (as mentioned) or normal noise. The louder the sound, the easier to find. If you're unlucky, just buy a used engine. One that you and a mechanic can listen to, check oil level, oil leaks, oil pressure,compression and maybe even drive it around under load to test it. You can buy 5-10 of those for $3K. If I were you I would buy a more modern engine. The AD guys here will tell you which ones fit. More power, better bearings, reliable. Chevy made some nice 6's in the mid 50's-60's and up. If you are a person who wants your truck to be totally original, buy a used one from that era. Denny says they last a long time so you have got a good chance to find a good one. A guy could to tear it down and then say you need a new block!, parts and labor are way high. Finding a guy who really knows what he is doing is not easy. Rebuild is sometimes a real PITA. For a total restore you need to have a "new" engine. You don't want to do all that work and have a used engine, But are you in that category? Buy a cherry picker and pull it out, very easy and mechanically straight forward. Keep all the parts that you can unbolt and $crap the rest. (IF someone says it's bearings or worn engine parts.)
Well if I weren't so dang busy with trying to make some sort of sense out of 40
years worth of collecting that I've got piled up from the move this summer, and if
I had three hands, 2 to adjust the valves and one to hold the camera and if I knew
how to take a video and knew how to post it.....takes a breath....I'd post one for
you to see Gus. But here’s an old Jam Handy film strip of a guy tuning up the
valves on a running Stovebolt engine at the factory in the 30’s. Skip down to 3:25
minutes on the video to see that part.
Also around that part of the film it shows a guy with a prop who is listening to the
engine for noises. Pop taught me that was the best way to adjust valves more than
half a century back and that’s the way I do it now. Here’s a fuzzy picture of the
New Britain valve-adjusting tool that I’ve been trying out lately. Never had one
of those back in the day, a stubby screwdriver and box wrench always worked
for me. http://www.pbase.com/dennygraham/image/136174534
Denny Graham
Denny G
Sandwich, IL
Denny I have a similar tool as the New Britain valve-adjusting tool. Except mine was made by Zim. It's what I use when I have the engine warmed up and running to set the valves. I adjust them by (ear) same as you and your Pop. I'll use feeler gauges to cold set the valves, but then it's Zim's turn.
1939 Chevrolet Stake Truck
Thanks for the link Denny.
I was wondering how it was done running. Looks easier without a fender in the way and in the shop.
I'm vertically challenged and diameter impaired so leaning over the bay didn't seem like a good idea with the engine running.
I'm going to give that a shot next time. In my mind all I could see is smashing feeler gauges.
I've been using the pointer on ball method (1 and 6 firing) but that seems to be frowned apon here.
Sorry for the hijack redlegs48
KOOL video Denny, I enjoyed watching that. Boy them guys sure earned their money.
Brian
1955.2 3100 Truck
Here is a web page with photos of the Zim-Zip, Proto, Snap-on, and New Britain valve adjusting tools
If anyone finds a video (YouTube or Vimeo) that shows that type of tool in use, please post the link.
Redlegs48 #903708 12/14/2012 11:42 PM
Yep, I ran into those way back when I was looking for one of
them Tim. I noticed then that the Zim tool is identical to the
New Britain tool. Zim is still making that tool to this day.
Oh yeah, before I forget, I've never hammered
a feeler gauge out of shape while adjusting
valves. If you do that you're cranking them
down WAY to much.
DG
Denny G
Sandwich, IL
just drive the crap out of it, if it blows get another engine
I had a noise in my van once, just drive it... could not make it go away or blow the engine...drove it that way for 2 yrs and sold it...
Redryder pix
My Hotrod
Back in high school in the late 50’s the little band of bad guys that I hung around
with, cruised around on Friday nights in a 49 Chevy 4dr stick shift. Back then you
could find an old Chevy beater for fifty to a hundred bucks. Craig, the guy that
owned the beater, worked construction so he had money to burn and didn’t really
care if he burned up one beater, he’d just go out a pick up another.
One Friday night we picked up our case of beer at the Old Mill Tavern and were
cruising around in the country sucking up suds and for some reason, probably
because the shifter box was worn, it got stuck in first gear. So he just drove it
around the rest of the night in first gear, wide open. Once when we stopped to tap
a kidney the old 216 was steaming like old faithful and when we popped the hood
the exhaust manifold was glowing bright red. Craig went on to drive that old
Stovebolt for the rest of the school year to work and all, and it never did give up
the ghost that I can remember.
They will take one ell of a beating and keep on tickin’.
Denny Graham
Denny G
Sandwich, IL
Redlegs48 #903812 12/15/2012 12:40 PM
Sir Searchalot
Sir Searchalot
That's right, run it, enjoy the sound. That sound is the sound of the good old days. All you gatta do is keep it oiled. I had a 56 Chevy 2 dr 265 V8 that smoked so bad I used 90 wt gear oil in it. Ran til I wrecked it. Is that RTIWI?
Redlegs48 #903967 12/16/2012 12:12 PM
I just got done adjusting the valves and it sounds 100% better. There are still some that are off a little but I no longer need ear plugs in the cab.
Also, in the process of idling for as long as I need I got more information on the oil problem. I probably had the truck idling in the garage for an hour, and when everything was all said and done there was oil and water right below the exhaust outlet. Any ideas?
Redlegs48 #903974 12/16/2012 12:55 PM
Do you mean where the exhaust head pipe attaches, can you link to a picture?
My Blog
No this near the rear axle, at the end of the entire exhaust system.
I already cleaned it up, so I am not sure how much a picture will help right now.
The combustion process produces a lot of water, it's normal for
water to condense at the end of the "tail pipe". If you have
some oil vapor condensing there also them it's just telling you
what we have been saying all along, you are probably in need of
an engine rebuild if you want to stop the oil usage.
Denny Graham
Denny G
Sandwich, IL
Guess I will run it for a while and see what happens. Thanks for the help everyone.
Have you taken compression readings?
Sir Searchalot
Sir Searchalot
FYI: It's called the tailpipe.
Redlegs48 #904084 12/16/2012 10:09 PM
Here were the compression readings:
1 - 98
2 - 92
3 - 90
4 - 98
5 - 112
6 - 105
Redlegs48 #904100 12/16/2012 11:07 PM
Sir Searchalot
Sir Searchalot
You are at 20 lbs from highest to lowest. Some books say should be less than 20 lbs diff. You're not terrible, but tolerable. Take it three times and make sure the throttle and choke are WIDE OPEN!! A 1949 216 is 110 lbs new according to the web. Squirt two squirts of oil into cylinder on test three. I assume a 216? I re read the post, no one ever said what engine this is? Can someone state what engine? Does it have babbit bearings?
Redlegs48 #904109 12/16/2012 11:44 PM
It is a 216... this post somewhat piggy-backed off one I had started few weeks ago.
I will not be able to re-take the readings until next week.
Sir Searchalot
Sir Searchalot
If you are going to run it til she gives up, you don't need to get more readings. I just thought you were still working on her. I read your other post now. Keep her oiled and take it easy. Don't fret over the engine. Do a swap when your ready. It's a nice looking truck! Fun I'll bet. Later.
Redlegs48 #904882 12/19/2012 11:46 PM
In my experience,"rod-knock" is usually more prevalent when engine is idling. If bearings aren't too-far-gone,the rod knock will be substancially quieter,or dis-appear when "under-load" If the knock quiets-down, when you let the clutch out,with your foot on the brake, the crank MAY be salvagable,so shut her down,pull the pan, remove,(in sequence),mark,(with masking-tape,and "Sharpie"), all the bearing-caps. Check the bearings,and the crank for scoring. Even if crank "looks O.K.,I'd still plasti-gauge the journals,to make sure they're in tolerance.you put the gauge between the bearing and the crank,torque the bearing to spec's,loosen,and remove cap,and the "spread" of the gauge reflects the clearance between the two. Test and record all bearing-caps' measurements. If crank is still "in-tolerance",I believe,(Not 100% sure),that you may drop the crank,(May need to jack the engine for this). If the journals are slightly scored,but not grooved,or gouged,i have been successful,using emery cloth to restore the surface. Just make double-sure surfaces are surgically clean before re-assembly. This will help prevent pre-mature wear,which would bring you back to this post way too soon. Hope this helps.
Mo' Tater
