6 members (Donf, mo2cyl, Barney1951, Steelonsteel, Stovebolt48, TUTS 59), 78 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#90359 04/05/2004 9:10 PM
I'm rewiring my 49 pickup with the CD aftermarket harness. I have three wires to connect to the two terminals on the switch. I have the hot lead to the switch (ok) and the lead from the switch to the stoplights (also ok) but I have a third wire that goes to the turnsignal switch.
I assume this is for the flashers and should be spliced into the wire going to the stoplights.
Is that correct?
#90360 04/06/2004 5:30 AM
The turnsignal wire does not connect to the brake light switch. If you want turnsignals you'll have to add a switch for them. If you don't just terminate the turnsignal wire.
#90361 04/06/2004 4:52 PM
I didn't think the turnsignal switch connected to the stop light switch either but the diagram shows that it does and the Chevy Duty tech told me that the stop lights run through their turnsignal switch. That may be how they get three functions, stop/tail/turn out of a single filament bulb. I guess I'll just have to experiment.
#90362 04/06/2004 7:59 PM
OK now I get it. I didn't realize you had the Chevy Duty turn signal switch also. Looking at the picture in their on-line catalogue it appears to be a signal-stat 7 wire model. You'll find a wiring diagram for it at SignalWiring
#90363 04/07/2004 2:51 AM
You will notice on the wiring diagram that the rear lights have two filaments. One is strictly for tail lights and the other is for stop and turn. When you just have the turn signal going, the flasher turns the light on and off. When you have the brake at the same time, the other side gives you the brake light. When you have no signal going, you get both brake lights.
1951 1 Ton Completed
