| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I have read quite a bit that if you swap over to disc brakes you would need to put in a new MC. Why is that? | | | | | Joined: Nov 2012 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 29 | A disc drum combo requires a dual master cylinder & proportioning valve for proper brake bias | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | And if you have disc and disc you still want a dual circuit MC for the added safety. You also want a MC with the required fluid volume/bore that suits your new calipers. If you swap the brakes front and rear from another vehicle you can't go wrong using the MC from that same vehicle.
Grigg | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | If you use the current MC and add a proportioning valve and residual valves to each line feeding the front and rear brakes, wouldn't that do what was needed to operate the brakes correctly? | | |
