0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90273 12/01/2003 8:13 AM | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | A few months ago I ran into a website that had these LED brake lights that fit into the bed hole. I thought that I had put it into my favorites, but it is not there and I can't remember who, what or where. Anybody know where I can get these????
Be Happy and Live a Good life filled with Love and Happiness.
#90274 12/01/2003 6:22 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Yell- I'm not sure if this is what you're looking for. These are lights that fit in the pan roll gap on older trucks. Some add them as third brake lights. Check out: Hot Lite\'z I know American Classics makes replacement brake light bulbs that are LED. Look in the Stovebolt link section for more options. | | |
#90275 12/02/2003 6:32 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The above Hot Lite'z link is right ... I put 'em on my truck and GLAD I did! Much safer driving, and it sure looks trick, eh? [img] http://AlanHorvath.com/54chevy/chevypics/bedroll_on.jpg[/img]
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#90276 12/02/2003 7:13 AM | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | That's it ! Thanks a bunch..
#90277 12/02/2003 5:54 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Alan-
Knew you had a link on your site. Thanks for posting the photo! It was easier to get the link from your info than dig through my other stuff! | | |
#90278 01/10/2004 9:45 PM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | horvath, how did you run the wiring on your truck for those smaller lights?
Just curious,
-W | | |
#90279 01/10/2004 10:07 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | W- Alan Horvath's site has step-by-step photos. I'm sure Alan can give you a direct answer when he signs on. Contact him by direct email if you need info ASAP. | | |
#90280 01/10/2004 11:02 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Are these lights 6 or 12 volt or do they have both? | | |
#90281 01/11/2004 3:04 PM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | 51PhatBoy:
Thanks, I will check it out.
Ok... I checked it out...
Yeah that is what I was pondering to do... if I bought any.
nifty.
-W | | |
#90282 01/12/2004 7:15 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Woogeroo -- Running the wires was pretty simple ... but first I had to get them to come UP the stake post from the tail lights down by the bumper. First, I set the HotLitez in the bedroll holes. The wires come out the back of the HotLite and the bedroll is open along the body-line, so it was easy to bring the wires out and down to a hole I (luckily) had in the back side of the stake post (see photo below), allowing me to run the wires into the stake post and down to my tail lights. After poking the wires through that hole, into the stake post, I tied a heavy nut on the end of a string and jiggled it down the stake post until it fell on the ground ... then I tied the ends of the HotLitez wires to it and pulled 'em down through the stake post and wired 'em into my tail lights. To hide the wires (see photo below), I used some black 1/4" split loom: [img] http://www.alanhorvath.com/54chevy/chevypics/bedroll_wires.jpg[/img]
#90283 01/12/2004 7:22 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | PS - Woogeroo -- There were 3 wires ... I had NO CLUE which went where (except for the ground wire, of course), so I experimented before doing the final splices. It was obvious enough. 46 inprogress -- Mine were 12 volt ... I dunno if they make 6 volt litez, but you can check their site: [Click Here] There's a Contact Link you can use to ask 'em, if you don't see anything.
#90284 01/16/2004 8:42 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Yep; Believe it or not the Led lights will work on 6 volts and they are not substantially dimmer
The reply I received from the company for everyone running 6V. | | |
#90285 01/16/2004 9:02 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | What is that handle holding your tailgate closed?
54 3100 with 235 62 flatbed dump C60 with 261
#90286 01/17/2004 9:53 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | It's a threaded "T-nut" ... the PO did that. It's better than having chains, eh?
I just twist 'em off and open the tail gate.
#90287 01/17/2004 1:42 PM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | What supports the tailgate when open?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#90288 01/18/2004 10:19 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I've got (clear covered) 1/4-inch metal cables left and right. Works nice.
