3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#902401 12/09/2012 8:13 PM
so I put my hood on the other day and noticed today that I busted off one of the bolts that screws into the hood. any ideas on how to get it out? would it be eaiser to find a new hood?
drill and easyout, visegrips if stub sticking out...
GMC: Get More Cash...
1958 GMC
My Webshots photos
I ended up drilling the bolt out and putting a heli-coil in.
Weld something to the broken bolt and use vice grips to remove.
1952 Chevrolet 3800 pickup
---All pictures---
How did you not notice when you tightened up the bolt? Just curious.
Sound like the bolt was previously twisted or weak. If it went in easily it should come out easily.
Careful drilling and an easy-out should do it like 1958GMCnut mentioned. Should not require a heli-coil unless cross threaded beyond cleanup/tapping or you used to big a bit.
Have pulled out many over the years that were extremely stuck.
don't drill thru the hood though.....
1958 GMC
My Webshots photos
Ive had hood luck using left hand drills to get broken fasteners out.
not much torque on the hood bolts, should back right out.
Not sure what year truck you have. If it was my 50 I would remove the hood to get a better shot at it.
I had the same problem. If it's sticking out a little (mine was) I used a cutoff wheel to make a slot in it and turned it out with a screwdriver. (p.s. don't forget to use penetrating oil!)
Saving American history one rust bucket at a time. When they're gone, they're gone forever!
hd4unm #909058 01/06/2013 7:53 AM
Don't know what happened on his but on mine the head was frozen in the hinge and broke when I opened the hood one day. I drilled it out and tapped the hole. Once I put new bolt in hood opened fine. The whole time with the stiff opening hood I thought it was the hinges not the bolt binding up.
DADS50 #909148 01/06/2013 11:28 AM
That's what I use. You can get them at any machine shop supply dealer. They are typically used in screw machines.
