0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | I was wodering what the last year gm produced the straight 6 cyl and cars they put them in? Thanks Chris | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | They still have a straight six, the Vortec, available in the small pickups. At least I think that is the case. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The Colorado pickups come with a 3.7L inline 5 cylinder engine. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | FYI The Colorado pickup and the GMC version have been dropped from the GM line. Ford has dropped their best selling Ranger as well. It appears GM will build a new replacement at the MO assembly plant. Ford is likely to have a new unit also at it's MN facility.
An Indian pickup from the Mahindra tractor company that sells here is likely to be the next smaller truck you see if plans continue to develop.
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | According to wikipedia the last inline 6's prior to the "Atlas" were made in 1990 (US). http://en.wikipedia.org/wiki/Chevrolet_straight-6_engineI only learned recently that Dodge/Ram dropped the Dakota in 2011, same year as Ranger. The best truck I ever had is a 2000 Ranger I've owned almost 10 years - longer than I've owned any vehicle... But small trucks aren't selling now as the were. And as good as fuel mileage is now available in full size... According to this Mahindra is DOA in the US.
Professional Novice
| | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | If I replace the inline 6 in my coe, I want to get the most modern version. The inline 5 sounds interesting. I think the hummer has a 5 cyl. Thanks for the responses. Chris | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The 5 cylinder is an electronically injected engine and the crank is not drilled for a pilot bearing. My wife drives a Colorado. She likes it but it is barely enough power for the small pickup. Putting it into a truck would be a big waste of time and money. There are some good 5 cylinder engines out there like a Mercedes Diesel, but they are just not practical to retrofit in an old vehicle. | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | GM makes a modern 6 cylinder with efi and makes a lot of horsepower. They should be in the salvage yards if you look. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yes Frank...NHTSA and EPA again. It begins to look more like our next small pickup or maybe any pickup will be a Tesla or similar electric thing.
lcfman...hope your not referring to the V6 Camaro motor. We're mostly inline guys here and the Atlas engine is now gone but maybe not dead. But the Camaro engine is a really strong unit and would be tons of power in an AD or TF chassis. | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | The humvee came with 6.2 or 6.5 v8 diesels. The H2s came with your standard gasoline chevy v8 that came in any tahoe or chevy/gmc truck. | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Well, the question I have is: Which modern engine would you put in a 51 Chevy COE in the same area as the original engine with the least amount of fabrication? Thanks Christopher | | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | GM has a fuel injected DOHC inline 6 cyl in the Chevy Trailblazer and GMC Envoy | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Well, the question I have is: Which modern engine would you put in a 51 Chevy COE in the same area as the original engine with the least amount of fabrication? Thanks Christopher 292 | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | The last year 6 cyl. that will bolt in is 62, Insert bearings and alot more vacum to run your wipers and 2 speed diff if you have vacum control. That's what I have in mine and I used the original manifolds,flywheel, bell housing and valve cover. | | |
