| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I need to replace the inner cowl panels on my 53. It looks like this involves removing the front clip. Are there some links to show step by step on how this is done? I might discover that the outer cowl panels need replacing too. JC shows a inner to outer panel. Are they usually needed and can they be fabricated? Need advice from you guys who have done this. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Brad, the pictures are really helpful. I am still trying to find the best way to dismantle the front clip. There must be a link out there that offers tips and techniques. Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Per the link above I had to remove my entire front clip after restoring my panel to repair a catastrophic failure of a staked rope seal retainer in the timing cover of the 455 Buick I have shoehorned in there.
Needless to say I was not happy, but proceeded. To my surprise it went by the book and with all the new nuts and bolts I used it really came out quickly. I carefully lifted it at the core support with the engine crane and rolled it back out of the way with no problems. Got it off in less than 45 minutes! I used a few tapered drifts to help align the holes for fenders, toe board, etc. while putting it all back together.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for the link Tim. This is great information. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for your interest Squire. Would you tell me what tapered drifts are and where to get them? Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Hey Tim, so THAT is what they are called. I have a bunch of em', use them all the time. Steve | | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Czechman has some good shots of his restoration/repair process.
All you can do is all you can do.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I would like to offer a tip for selecting the best inner cowl panel. First, there is a full panel that has an awful gray primer offered by many of the vendors that does not come close to fitting at the bottom. Some of the vendors sell the lower half of the panel that fits VERY nicely. It comes in black primer. I ended up buying both of them (as I needed the whole panel), cutting and splicing them together for the right side. This worked much nicer than cutting, bending, re-cutting, re-bending, cussing, throwing parts and tools, yelling at my lovely wife and children for no fault of there own trying to get the gray @#$%^&*() panel to fit the left side. I think that panel may have taken some years off the end of my life. Don't get me started on the poor-fitting replacement inner-to-outer cowl (also in the horrible gray primer). With all the aggravation that I suffer from working on these old trucks, nothing makes me smile harder than hopping in and driving one that I built!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...much has been written about that very panel. Consenus is/was that regardless of where it comes from you just about have to beat it into submission. Your now a member of the inner/outer club. Get a BIG Pepsi and do a search on this. HOURS of reading. | | |
