7 members (ronsway, Peggy M, Otto Skorzeny, papas52, Jack Ryan, 2 invisible), 76 guests, and 2 robots.
Topics128,087
Posts1,056,340
Members48,442
#901006 12/03/2012 9:15 PM
I finally get to claim the 51 GMC 3 ton 470 as mine now smile It's an old army truck with what appears to be 53502 miles on it. Very solid with one cab corner needing a little work as does the drivers side floor, but no dents and solid otherwise. Wood in bed is shot though. Anyway I'm pretty excited about this old army/farm truck.
Here are a few pics....
Regards,
Troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Yes, that is a nice old beast. You seem to have the original steel around the bed. I think you are going to have a lot of fun with that. Congratulations!
1951 1 Ton Completed
Thanks alot trucker ! It is indeed all original and straight. It should be within reach of doing. Like you said, it should be fun smile
Troy
1963 Chevy C60
Big Red Chevy
Is it a 450, or 470? A 450 is a 3 ton. 470, a 3 1/2 ton.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
I guess you got me on that one... I thought it was the 3 ton but I think I mistakenly listed it as the 470. Now I'm not sure :0. The code on the engine block shows a270783i87 and the serial number shows HC453 10746. That's about as much as I can tell right now. So, I don't have an answer. I guess I can do some more research and get back.
Troy
Troy
1963 Chevy C60
Big Red Chevy
I'm not sure about the "Jimmy's",but aren't the 6-hole,6-bolt "Budd's" on the rare side for a '53? Maybe not for the 3-31/2-tons,but I haven't seen one up-close and personal,since my best-friend's brother had a '53 G.M.C.450 road tractor,also old Army issue.I can't remember if the "Budds were 5-lug'or 6-lug'though. But believe it or not,they were chromed! My guess would be NOT military-issue. Truck also had that "double" hydra-matic,but he didn't have it long enough for me to get a good look at it. I heard it's sitting in a junkyard somewhere here in Eastern Iowa,and I've been looking for it for years,and if and when I find it,I'll post some pic's. Nice find,Red63!
Mo' Tater
Thanks, Wetwilly... This truck does indeed have the six bolt/lug wheels... I believe the tires are 10x20's. I'd love to get more history on this big ol truck as it could clear up a few questions some of us have. For a fact it was used by the military base, Redstone Arsenal, here in Huntsville. It still has a chrome id tag that states 'RA....' I'm told thats 'regular army'. It still has the original military markings in cab and has plenty of hooks and loops on sides of bed. I'm real inclined to leave pretty much as is. Now comes the fun of getting it back on the road... I think it shoud be fairly easy, at least I hope so smile
Heres another pic or two after i cleaned it up a little smile
Thanks again for weighing in.
Troy
Troy
1963 Chevy C60
Big Red Chevy
It is indeed a 450 series 3 ton. The 450, & 470 series GMC trucks came standard from the Factory with the 6 lug "Motor" Wheels, not Budd brand. Dayton wheels were an option, for 450, & 470 series. 10 stud "Budd" wheels were also an option for the 470 series trucks.
Spanky Hardy
1950 GMC 250 1-Ton
Thank you Spanky for clarification. I look forward to sharing my progress with you and the rest of stovebolt nation smile
Troy
Troy
1963 Chevy C60
Big Red Chevy
Wow that truck looks identical to mine even down to the serial. Have you had it out on the road yet?
1951 GMC 450 3-Ton Tanker
"The Big Boy"
More pix on Photobucket
Hi Red63
I have (2) 1952 454-30's They are 3 ton w/179 inch wheel base, 302CID engine, Clark 5 Speeds and one has an Eaton 2 speed electric shift axle, the other is a Timkin single speed.
Model numbers 450 series equals 3 ton, the "4" in 454 in 179 inch wheel base.
Your 453 is a 3 ton w/270CID (1951) engine and 161 inch wheel base, most likely has a Clark 205V 5 Speed and either and Eaton 2 speed axle or a Timkin single speed axle w/6.80 ratio.
Optional Transmission where Clark 205VO, Clark 207V, Clark 207VO and a Borg Warner 5 Speed. The "O" in the Clark VO is for 5th gear overdrive. "V" is 5th gear direct.
Wheels are Motor Wheel 7.5x20s 6 hole, hub pilot, w/Compression lug nuts and probably with 8.25 tires or 9.00x20 tires.
The Carburetor is probably a Holly 660A or 660A1.
Yours probably has Hydro-Vac brakes.
These trucks also came as tractors for semi trailers.
My curb weight is 8500 lbs, GVW is 19,600 and Combined GVW of 36,500 lbs. It requires a CDL (Commercial Drivers License) this is a Federal Standard now.
They came with Hydro-Vac brakes, Air Package Brakes (Air over Hydraulic) and Straight Air Brakes.
Good Luck and Happy Trucking.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
GMCpic, wow thats alot of info there... I am excited about getting to have such a cool rig. I will try and take this one step at a time... You and others have been very helpful and I very much appreciate it smile
Thanks for taking time to share.
Troy
Troy
1963 Chevy C60
Big Red Chevy
One more point of interest... My data plate states my vehicle is a hc453, gvw is 19000 lbs and the maximum gross combination weight is 34000 lbs. Does that still mean I need cdl's to operate this vehicle ?
Troy
Troy
1963 Chevy C60
Big Red Chevy
Not yet, i got gas tank issues... After that is all worked out comes brakes... Then I will go from there... I can't wait though smile
Troy
Troy
1963 Chevy C60
Big Red Chevy
1 Offline
You should be able to lic. this rig, at 25,900 gvw, as a single unit, without needing a CDL. Air brakes and towing a trailer, will put you in the CDL range. 26,001 and over needs a class B lic. unless this will be used strictly for farm use.
Joe
The older I get, I only want to work on older rigs.
In Arizona I got licensed for mine no questions asked. At 19,500 Im below CDL requirement but if I tow anything it could put me above.
"The Big Boy"
